Here is some of the stuff that I have and use in various conditions, conditions dictate which I will use, I'm only mentioning some of the stuff that I have.
Unfortunately the only "original recipes" I believe in is Chutney and maybe Whiskey...
I'm not brand loyal, never have and never will be, I use what I believe offers me the best value for money and suit the conditions that I fish in.
Rods
6.6ft Berkley CherryWood 2pc Rod (lure 1/8 - 5/8oz) (about R 300)
7ft Elbe Interceptor 2pc Rod (lure up to 1oz) (About R 300)
7ft Elbe Interceptor 1pc Rod (lure up to 1oz) (About R 300)
8ft Sensation Passion Stick 2pc Rod (lure 1/4 to 1.5oz)(About R 500)
8ft Daiwa Exceller 2pc Rod (lure 14g to 56g) (About R 800)
8ft Elbe Estuary Pro 2pc Rod (lure 20g to 40g) (About R 180)
9ft Berkley Air 2pc Rod (lure up to 3oz MAX) (About R 1400)
Reels
Shimano Alivio 2000 Grinder (About R 200)
Daiwa Regal 2500 Grinder (About R 350)
Daiwa Exceller Plus 3000 Grinder (About R 1000)
Shimano Corvalus CV300 Multiplier (About R 800 I think)
Daiwa Oceano 4500J Grinder (About R 1300)
Shimano Stradic 8000 Grinder (About R 2000)
and then another few grinders that I don't use often, all loaded with between 4kg IFGA line to 8kg mono line
Line (can't remember the costs)
Berkley Fireline 6lb - White - 125yds
Berkley Fireline 8lb - Yellow - 300yds
Berkley Fireline 10lb - Pienk - 300yds
Berkley Fireline 30lb - Black - 300yds
Mustad Braid 30lb - Yellow - 300yds
PowerPro Braid 50lb - Green - 300yds
4lb IGFA Kingfisher Line
Now the pairing of them
use either
or
or
or
Now based on this, note that I don't carry all these rods with me when going fishing, I use different setups based on conditions and location
from the rocks
I will take atleast the 6.6rod and then choose between the 8ft of the 9ft depending on where I'm going
from the Surf
I'll take the 7ft and the 9ft
from the boat in the river
I'll take the 6.6ft, 7ft (both) and the 3 8ft rods with various reels, but for sport would mostly use 4kg igfa line
from the boat at sea
I'll take 1x7ft rod, 1x8ft rod and the 9ft rod
and use the Exceller Plus, the Oceano 4500 and the Stradic 8000
The rods cost anything from R 150 up to about R 1400
The reels cost anything from R 250 up to about R 2000
Line, well there you know
In most cases I prefer to not use mono for backing on my grinders, I prefer to load spool with either braid all the way or mono all the way, the only exception is the Regal which has 4kg Mono as backing (on the one spool) and then 125yds of Fireline as topshot, but this is a very very light setup not meant for big fish that would take that much line.
For a person doing both rock and surf on a not so serious note I would recommend the following :
One outfit
Elbe 7ft rod with either Daiwa Exceller 3000 or Daiwa Regal 2500
This outfit can handle a wide range of lure weights from 1/8 up to 1oz
Two Outfits
6.6ft Rod with Regal 2500
8ft (Passion stick or Exceller Rod) with Exceller 3000
The light outfit is great for fish up to 3kg and lighter lures, especially in the rivers and Gullies
The heavier outfit is great for Heavier lures and longer casts in the surf, and if you do your work can handle fish up to and over the 10kg mark with ease.
For the fanatic
8ft rod with Exceller 3000
9ft rod ith Oceano 4500 or Stradic 8000
here you have everything you could possibly need to take on from .5kg fish right up to the monsters of the rocks and surf !
It depends on many things including your budget, how serious you are about fishing and most important, YOUR NEEDS.
