Pentagon Medium
Joker
Over the weekend I had the opportunity to cast my pals Pentagon Medium with a medium tip.
Setup: Tor20 spooled with .42 xx and 6oz sinker. Whole pillie.
Casting at night so I could not see the distance I achieved. What I found though is that the rod is quite stiff. It did not feel like I was doing justice to such a fine rod.
Was the sinker I used wrong? Should we have used a 7oz and the whole pillie?
I tried the overhead cast and my adapted pendulum. Still a work in progress, I must admit.
I'm thinking of buying the said rod.
Thanx for the input.
SS
Hi Joker. I take it that the rod is the t53 hmg Pentagon?  I have the slimline version, with medium and heavy tips.  It is a fantastic rod, but does take one a few casts to get used to the faster action of the hmg.  I use mine with a saltist 40 and it is perfectly balanced. With regard to distance there is no comparison and I cast substantially further than I do with other rods.  I use a 6oz on the medium tip with a conventional casting style.  For more information, I suggest that you contact Rob Gavin from Gremlins personally.  If it is in decent condition and you can get it at a decent price, then buy it, you wont be sorry.  Try casting with it during the day on an open field or deserted beach, that will give you a better perspective.
Joker
Hey SS
Thanx for the reply. Yes, it is a T53 Pentagon Medium.
Will try and get some more practice using the said rod. I can feel that it will be able to handle any fish that dares to take the bait.
Moyeni
Howzit Joker,
Well I have had my new Pentagon Medium for about 2 months now. And all I can say is that this rod is truley a lovely casting rod.
I matched it with my Saltiga 40. I have been using it for garrick fishing over the past month.
I throw a 7oz grapnel sinker with no effect at all. The tip is rated 5-7oz. When I slide my live bait the tip is very forgiving.
This rod will pull any fish including non-edibles any day!!!
darrenk
First time I ever used my medium I paired it with my saltiga 40. Its such a good all rounder - first cast I got a diamond of 43kg... Then I got 2 nice blue rays and 2 sandies..then threw a bigger bait and got a raggie of 165kg.all from the surf. Used .45mm mainline and changed to a 0.90mm leader
Joker
Hey Darren
I have no doubt that the Pentagon M is capable of landing any fish.
1. Which sinker do you use when casting a smaller bait?
2. Which sinker do you use when casting a bigger bait?
darrenk
I generally use a 6oz for everything...have used a 7oz and a pilchard bait before while scratching in a bigger sea. But prefer the 6oz
