Pentagon HMG Medium
esatpil
Hi Guys,
I got a quote yesterday for a Pentagon HMG Medium.
It worked out to R3350
Is that a fair price guys?
christodeb
Hi estapil i bought a Pentagon HMG heavy a while ago, and i absolutely hate it! The rod is a lot heavier in weight than my Purglass 350/4. I aslo found that my casting distance with the purglass was at leat 30m more than the Pentagon.
The point i would like to make is that you can either save yourself R1000 and buy a WAFT heighlander 3 piece, hich would give you the same performance if not better than the Pentagon, or you can buy something like a WAFT Iorn feather or Pirate which would outperform the Pentagon by a long way.
Dynamite
I have personally never used the Pentagon range but have only thus far heard great things about the rod, so i must say i'm quite stunned to see you hate the rod. I know that the "Angling with blackfin team" and i know 3 of them personally and they are quality anglers. Wesley, Kyle and Andrew use it. Bryan preferes the Assasin. Then again you have to find a rod that best suits you, and there are so much criteria that esentially determine the rod that will suit you.
scorpion
hey christo, u dont say if it was an hmg or not, gremlins make good rods, if you got a standard graphite heavy it will be a bit on the heavy side, also how you specced the rod. the waft 3 piece is better value but i have not seen the build of the rods yet.
esapil you obviously specced your rod with pacbay guides shrink tube over foam grip and trigger winch. phone waft spec the rod exactly the same let us know what price you get.
esatpil
I guess LCTCG means pacific bay guides.
Trigger Grip
EVA Foam Grip
@Shark Attack - I have heard that the Blade is one rod that takes some moer of power to load,I am only 1.76m in height and really not built like a rugby player so I doubt I would be able to chuck with the blade
Dynamite
Trigger Grip
EVA Foam Grip
It's a great rod, as you can see i own 2 of them, but yes you do have to be fairly sturdy to cast it effectively and if you not an overweight guy or strongly built i would not advise it at all. Also being a short rod you need a quick strong action in casting
DWB
Esatpil.
Check out the new ASSASSIN Surf series.
Truely phenominal rods, and should be less prune to breaking than the previous series. Their price range is also much better.
If i was you, id check these out.
www.basilmanning.co.za
christodeb
I've got the HMG with the short tip. There is nothing wrong with the rod i just don't think it's worth paying R3000+ for a rod when you can get the same performance for a lot less.
Weedeater
[color="#006600"]esatpil[/color] wrote:
Hi Guys,
Huh? What the... I paid R1000 less than that in December last year! That is very heavy! For that price range, I would go for a WAFT Highlander 3 piece, custom spec'd though.
Christo,
Quite surprised to see you don't like the rod. The Pentagon Heavy HMG/Medium HMG with heavy tip are hard to load, in fact more so than my Assassin Heavy Competitor HMG, but probably because Gremlin's use T53's and not imported chinese blanks.
Take a while to get used to, but I'm fairly confident with my medium now and love the rod.
But go to agree with you on the Iron Feather/Pirate, leaning more towards the Pirate. They are brilliant quality blanks, I have tested them and they are amazingly strong, more so than anything else I've ever come across.
For your height and build ESAT, I would stay away from anything heavier than a medium HMG with heavy tip, or you will battle to load the blank.
christodeb
Hi Guys,
That might be the reason why i struggle with the Heavy HMG (I'm 1.68m). I think it's time to sell that bugger and get me something that loads a lot easier. I also favour the one piece rods more due to no flat spots on the blank.
scorpion
christo you will love the big brother, a very sturdy rod that loads easier than most t53 blanks. the rods does eds and non eds comes with 2 tips. it's a 2 piece rod and is very smooth. it's one drawback is that it does not slide as well a heavy hmg, it takes a bit longer to get the bait out.
christodeb
Thanks for the advice Scorpion i appreciate it. I think i must let go of the Pentagon asap and get myself a big brother. Do you know how much the big brother sells for?
Weedeater
Hi Christo,
About R3300 with 2 tips, not sure if they do that anymore. I know Azziz mentioned to me they were now making a 2 piece (1 tip) but the tip is made from the same material as the Pirate.
How much you looking for to get rid of the Pentagon?
Johan S
Strange, I bought mine beginning of April and paid R2900, and that was with the P-bay guides, trigger, the combination eva/shrink grip and postagte to Pta. You did mention you are going for the medium, I wouldn't go for the heavy (according to the guys at Gremlins they use a different type of midsection on the heavy), as I, not being the worlds most proficient caster, struggles to load the rod. Then again, I struggle with just about any rod :/ My problem is that I'm to scared of overwinds to punch the rod just before sinker release. Would I trade the rod for something else? Would I buy something else if I had to do it over again? Not a chance!!! (Brendan/Rob, you guys better give me some commission, ok? :lol: Or some discount on my next one)
Weedeater
Johan,
It really is a brilliant rod, I am very happy with mine. Are you comming to the social next saturday? If so, maybe I can help improve your casting. I find if you tighten your reel spool and focus on watching the spool when casting, you can really punch it without getting overwinds.
hms1
Hi Chaps.
I am one of the lucky ones to own three of the Pentigon HMG rods and i love all of them. For sure that heavy takes a lot of power to push a sinker out their.I got my medium two weeks ago and i have all the convidence to cast that rod and i am as happy as apig in you know what with it. i can get that rod for you a lot cheaper if you like, give me a call. You are not making a mistake when buying one, trust me.
