Penn powerstick12ft
Brett Naicker
Hey guys well2day i got a penn powerstick pro12ft the one wit the wooden butt.rod feels great told it can handle around a 6oz sinker?not sure..any input bout pulling power?wanted it4rocks at baileys and kalk bay as well as an ed rod at the surf..will this work?got told its very dependable and tough workin machine.oh its gona be paired wit a sl30.11kg giant abrasion..usually thro a5oz max6oz..could i land some decent ed's?was very two minded so,ya...
PLEASE TRY POST IN THE CORRECT SUBFORUM.
ADMIN
Mossie2
Hi Brett,
I have exactly the same set up as you and I have landed several Smooth hounds (up to 1.5m) without any problems. I think the reel will go before the the rod fails ..... and I cast up to 7 oz grapnel sinkers with a smile.
Also use this setup to fish from the rocks and you can stand the whole day with this combo .....
I think you made a good choice ....
Thight lines
Brett Naicker
::SHey mossie,thank u very much for ur input.how far do u roughly cast?and wot line do u use?weight etc..i am just worried coz i found i have a very jerky action wit a shorter rod.do u also fish with a leader?coz these guides are bigger than that of my old blue marlin so wanted2try and cast about a 0.5mm leader.
Mossie2
Brett, I use 21kg braid backing with 0.55mm KFGA as top shot with a 0.7 mm leader. Fishing "The point" and "Paaltjies" in Langebaan for Smoothhounds with the sharp ledge and musselsbanks you dont have a choice but to fish with a leader. Distance? Far enough to get to the Smoothhounds - ::S
Brett Naicker
Hey guys just took the powerstick out on the surf2nite.using it wit a sl30 11.5 kfga and a 18kg leader casts like a dream.neva caught anythin yet but cant wait.wit a 5oz i get serious distance.Prob wana take it out to the baan next week sometime.
Smirre
G day Brett
Great combo. I use a 14ft Penn Powerstick and a Daiwa sl 50. 30pd king fisher high abration line. sometimes a leader but mostly stait up for sand bottom. casting a 10oz grapnel sinker with heavy tip with ease, distance on heavy tip with 7oz was measured at 120m. my oppinioun, you can take it anyware, it will take the punch anyday. caught a big something at Bangnek in April, put me and my rod through our paces before biting off a steel trace. the rod and reel took the strain well and it gives you good controll. what I did, inside the reel, on the rachet side there is a brass ring and a thin rod through the centre of the reel shaft with two plastic bushes that helps to put cyntrifical drag on the reel to prevent overwind. Once you are comfortable with your casting skill, open the reel and take the two bushes out, gives you a free spool all the way and ads a few meters on the cast, specialy on heavy sinkers. enjoy..
