Penn 500 repairs
boerrie
Hi all
Please could you guys help me out here.
Does anyone know how to remove the clicker tongue? as you can see in the photo it is really badly worn and does not work anymore.
Have any of you guys had a similar problem?
regards
peter
p.s I have tried to post this in the reel repair forum but i am unable to post there?
do i need to contact admin about that. i dont like posting in the wrong sections if i can help it.
Boerrie... I'm snookered bud. Think you might have to replace the entire Side plate... dunno if that would be a cost-effective way of doing things though?
Guppigetta
Hi Boerrie,I think that clicker is pressed together, almost like a rivet that is pressed and not hammered.I suggest you grind away the piece on the inside , pull it apart and then make a new button and shaft. Drill a hole in the shaft end to make it easier to expand it with a centre punch and small hammer. When it is expanded slightly you can then press it tightly with a small press vice. My 2c. Hope you come right.
Guppigetta
Hi Boerrie, me again.Got thinking of your predicament and decided to do something. I managed to get hold of a broken side plate, pulled it apart and made the clicker pin to fit.The clicker is still in good condition. If you haven't come right yet, give me a call on 0832942872 to arrange for the plate to be sent to me so I can put it together for you, or else I can send the parts to you to fix it yourself.
boerrie
sparky2009 wrote:
boet if you haven't come right yet let me know i got 2 penn 500's both with broken spools you can have them
that would be great boet. still havent come right with it. the only way i can see of doing it is to drill it out and replace it but cant get spares anywhere. i have now ordered but am looking at feb or march for the parts to arrive. how much you want for one?
thanks boerrie
