PE lines?
PE lines...
PE lines are nothing more that just braided line. I read an article somewhere that the PE table is a measurement system used by the Japanes and it has stuck around in jigging circles.
I.E. PE2, PE4, etc.
Does anyone have these tables or know what exactly these equate to?
Bennie
PE number actually refers to the lines thickness
From my understanding PE is the system used to categorize the diameter of silk twine. It has been transfered over to fishing line in japan to give the diameter of spectra lines.
In essence PE 6 may represent 60 lb strength with one brand of spectra and 80 lb with another brand. The strengths and diameters of spectra lines are highly variable when compared to monofilament. Most monofilament has a strength directly proportional to the thickness (most monofilaments that claim to have a much higher test strength do so because the line is thicker). This is not the case with the different brands of spectra because because both the number of strands in the line and the way in which the strands are braided will affect the strength and diameter. Higher quality lines will use more strands, a tighter weave and thus be more smooth and stronger for the diameter.
To get a rough estimate of line rating, multiply the PE rating by 10 to get the line rating.
Example: PE 6 = 60lb, PE 8 = 80lb.
Thanks!
You are spot on about the silk story. I believe the Japs actually used silk as line before the advent of Dyneema and Spectra!
Nepptune
Hey guys,
Correct, PE is a measure of diametre, not strength... roughly the breaking strain equates to the PE number multiplied by 10, i.e. - PE 4 = 40lb, as mentioned by do pescador... this has been pretty well surpassed by the top lines though, as they have much higher breaking strains... eg, YGK Ultra Jigman PE 6 has an 86lb average breaking strain....
Here is a basic PE measurement table.
PE Ratings
PE No..mm
0.6...0.128
0.8...0.148
1.0...0.165
1.2...0.185
1.5...0.205
1.7...0.218
2.0...0.235
2.5...0.260
3.0...0.285
3.5...0.310
4.0...0.330
5.0...0.370
6.0...0.405
7.0...0.435
8.0...0.470
10.0...0.520
12.0...0.570
14.0...0.620
16.0...0.660
18.0...0.700
20.0...0.740
22.0...0.780
24.0...0.810
28.0...0.870
