Part for a diawa reel
Razeen
Hi
Anyone  know where i can get aside plate for a grandwave 30 z , i tightend the screws and the spool wasn't aligned and the pin came thru the side plate ow, there's a hole in it. I glued the piece back but it does fit 100%. i now have play on my spool although the tension knob is tight.
The shops has to order from diawa and they closed. Keith doesn't have a plate
Ouch buddy...guess your gonna have to wait till the new year...maybe you should see it as a sign to flex your credit card a day before christmas and spoil yourself..
Razeen
If it is Shim... you wanted to say Hooked then its too bad cos i swapped my shim.... for diawa's those reels are just too heavy for me...
Polychaete
Razeen, if the sideplate is the same as its bigger brothers and if you can wait til mid January, I may be able to give you a chritmas present. Once you hear what Kinfisher will charge you for the part, you will be happy to wait.
I think the 30 is smaller though.
I have quite a few bits and pieces of Diawas in my parts box.
LOL LOL
Polychaete
Is it the same as the 40 or 50 wide Diawa's....my gues is the 30 has a smaller diameter.
Drop me a PM round 16 Jan 08 if you believe a 40 or 50 side plate will fit.:D
Razeen
Poly
I'll check if they the same and i;ll give you a shout. need to either measure or try and fit someone else's to40 or 50 to my 30
EarlBart
I had the same problem with mine.The agents could not give me a price as the reel has been dicontinued.Use the normal 30's plate as it fits.The problem is that it is black.Let me know if u do find a replacement
Razeen
Anyone has a Sl30 for sale? this is probably the only way i will be able to replace the side plate. Fred Tucker has an old price of R290 and kingfisher wnats R190 so i thought if i can get a 2nd hand reel for a good price it will be better than just buying a side plate. Stock is only due end of this month in any case,
Was thinking of taking it to a plastic reparing place or someone who can cast a new one.
Polychaete
There is very little pressure on the side plate, so it may be possible to repair it somehow.
Post a picture of the damage, maybe someone has a plan to make.
What is the precice model no and is it the left or right side?   A friend is sending me some stuff from the states perhaps he can source one somewhere.
Razeen
Poly
Its the left side the ratchet plate. I sealed it with pratley steel. but the saltwater eats it away after a day or 2 at the beach wading. The part that broke off doesn't fit perfectly in, i don't know why. the problem is that the spool is loose although the thumb spool is tight and the broken part is glued back its like1mm play. I put 2 red brake blocks in so it doesn't give me overwinds.
I ordered the part from Goodwood Sport, Daiwa only opens on Monday and then another week to get the part +- R190. Tucker wants R290 how do they justify that.
Kingfisher also R189 but then i must still pay P&P.
Thanks for all your help. Only problem is that its not the exact one i want the Grandwave Z is silver the one in Harry's Avatar. They discontinued that model so i have to put on a Grandwave X plate which is black. If you friend can source a Z then when can talk.
