Painting sticks
fishersteve1972
Asked Bennie this in a pm and he asked me to create a post so everyone can benefit from the info.
If anyone else has any experience feel free to answer/add
If I use acrylic paint
* do I need a certain type of wood primer (if using sanding sealer)
* do I need a certain type of wood primer (if using lindeed oil/white spirits as
sealer)
* can I use devcon 2ton epoxy or envirotex as a top coat
I'm pretty much set on using acrylic paint but heres some regarding automotive paint.
If I use automotive paint
* can I still use sanding sealer
* what primer would I use
* again what type of top coat (must it be 2K)
Some guys dip there lures in a thinnish epoxy,what type is that.
Steve
Hi Steve,
Firstly, I have never been able to get Envirotex locally and being nervous trying to bring a liquid in, I simply avoided it and only use 2-k automotive paints. So I can really only answer the latter!
Yes you can. But what I have been doing is sealing the raw wood in a heavily diluted solution. In the past I used PU floor varnish, thinned with 2-k thinners. These days, I simply dilute a little clear coat + hardener + thinners in a heavy plastic bag and swish the lure around in this. This will seal the wood. It isn't the ideal way to do it but is it fast and will seal the wood fairly well to prevent rot.
Use an MS Primer. It is actually a filler primer that doesn't require hardener. I think you could use this primer regardless of paint actually.
Once it is sealed, I lightly sand the lure with 400 grit paper just to smooth it off a little. Then I prefer to brush the primer on. Sand this and then spray a very thin coat of primer. Sand this with water paper and water with 800 grit to prep for paint.
2-K paints is what we have readily available in SA. Best selection, bets prices and you can get any colour you like mixed up very cheaply. I only use the basics and mix my own colours. Buy paint in the smallest quantity they will sell to you, you don't need much!
Epoxy floor varnish, PU floor varnish or read above...
All that said, I have used Molotow paint. Excellent coverage! This is a non toxic paint, but I find over spray to be a real pain and bleeding of colours not as smooth. I have used it, works great but I'm not a fundie. Their pens are also great for making markings on the lure.
http://www.molotow.com/
The S.A. agent - http://www.capsandcans.co.za/
One important tip. Only use 2-k thinners for everything. Even with the floor varnish (if you choose to use it). Otherwise the thinners can clash stuffing up your nice paint job.
If you use the floor varnish, you have to leave it for at least a week before painting. Even if paint is "Dry" it will still give off fumes for days.
If you want a really, really hard 2K clear coat that seals and hardens very fast try de Beers HS Scratch Resistant Clear from Holland, available here in RSA.
http://www.de-beer.com/bestanden/products/cc.pdf
Can you buy direct or must you find an agent? Would be very keen to find somether better.
My automative paints dealer has it. was looking for something much harder and that would cure quicker without baking and never looked back since getting this stuff.
Limpopoking
sealer)
Steve
Hi Steve, general rule of thumb is stick to compatible subsequent coats. There are a few exceptions to the rule but for example, if you start with an acrylic primer, make all subsequent coats acrylic based, nitrocellulose with nitrocellulose. Epoxies are a little more tolerant but it's still better to stick to the recommended primers even within brand recommendations (ie: If using BillyBobs 2k primer, go with their colour coats and topcoats)
Adding pigments should also come into the discussion but maybe someone else out there can offer more expertise than I can, not having messed much with colour (my area of expertise is general joinery, restoration and wood technology).
As for Linseed oil, boiled or raw, I have no idea why this stuff is even still sold. It's actually hydroscopic (attracts moisture) and has no place in wood protection. It does not strengthen the wood surface, doesn't enhance abrasion resistance and as just mentioned, doesn't act as a moisture barrier. If one wishes to go with natural finishes, then the likes of Tung oil or Danish oil are infinitely superior. In fact, Tung oil is pretty awesome stuff but I wouldn't be using it with lures.
Interestingly enough, one of the most effective moisture barriers has proved to be paraffin wax. At some stage, I'd like to build a few lures out of hard light coloured wood (maybe Maple or Pau Marfim) and then dye the colour into them and finish up by boiling the completed lures in wax. Will be interesting and fun.
I must really have a chat to Hennie Papenfuss about those Rage poppers of theirs. the pooper are covered in a clear scratch resistant epoxy.
20 minutes with a screwwdriver and throwing the lure against a brick wall till I felt I would have tennis elbow and I had hardly made a mark on the poppers.
Local stuff he gets from some epoxy company in Rosslyn
