Advice needed:
I have a 3 piece fishing rod and the joint was a bit tight. I sanded the male part of the mid section. But I sanded a little too much off. Now its loose.
What can I use to solve my problem?
Superglue. I prefer the bostik gel. It takes a bit longer to dry. Use a rubber glove or clingwrap over your finger and apply a thin coat. Let it dry, and then CAREFULLY sand it down with 1800 grit until it fits the way you want
