Outboard problems
Droomvanger
I had a small oil leak on my outboard - 100 fourstroke Yamaha - and took the boat for repairs to a dealer. The following parts was replaced: Bottom Engine seal, oil pump top seal, dust seal, O Rings 2, gasket base, leg drive bush, engine oil. The boat perform 100% before I took it for repairs. The first time I went on the water after repairs with the boat, I experienced Big Problems very soon. It started well, but soon starting to run as if it does not get fuel - it ran unevenly. I stopped. Start again and it started with plenty of smoke - never smoked before. I drove further and again experienced the uneven running of the outboard. Suddenly plenty of smoke poured out of the outboard - I thought it is burning inside. I switched off the ignition.  I took out the fire-extinguisher, but the smoke got lesser. I have not started the engin again, but noticed white oil -(water and oil mixed?) dripping from the outboard. I phone the dealer from the water, and he denied that the problem is anything related to what he did on the boat. The impression I got is that maybe a gasket has blown, or worse. Is it possible that taking the work that has been done on the boat that the breakage is due to faulty workmanship on the part of the dealer? Any advice what direction to take now? I don't want to take it back to the same dealer, because he already have denied any fault on his part. If I take it to another dealer, what needs to specifically recorded to dermine fault, if the case is turning in the courts. Your expert advise is appreciated.
bernssurf
Hi Droomvanger. Just do a simple check and have a look at your oil level on the dip stick. It is possible that the dealer might have put in too much oil. The white smoke you see could be from oil instead of fuel igniting on top of the piston. Otherwise it could be rings.
rianc
Dis 'n slegte een Bernard! Wat Roy sê maak sin. Die sparkplugs sal jou 'n baie goeie indikasie gee as daar olie deur gekom het.(nat olie plug, of swart)
fishalitis
Droomvanger cant help u without further info:
1 Where about was oil leak on the outboard if known
2 Year model of outboard with brief history
3 Was it a Yammie dealer who did the repairs and if not yammie which brand does he sell.
4 What was the prognosis of the oil leak and was there a quote provided before strip and repair.
5 Why did you choose the specific dealer.
willem wikkel spies
stadig hier broer.
lets get some more detail.
place some pics and sort this out.
dit help nie ons praat in die lug nie.
droomvanger;
fotos van alles, plugs ens.
tans is dit onduidelik.
groete
ss
Droomvanger
@ Fishalitis
1 Where about was oil leak on the outboard if known - At the bottom engine seal - between the enjin and the leg part. The oil pump seal, dust seal, gasket base and o rings and leg drive bush were replaced.
2 Year model of outboard with brief history - I can't remeber what year model the four stoke is - about 2000 - I will have to look but the boat is back to a Yammie dealer for repairs. The Yammie has received regular services and was in a very good condition.
3 Was it a Yammie dealer who did the repairs and if not yammie which bra - nd does he sell. - Not a Yammie dealer, but I was referred by a Yammie dealer to this dealer. The parts that was replaced was Yammie parts.
4 What was the prognosis of the oil leak and was there a quote provided before strip and repair - The dealer told me that the oil leak is not serious, but I request him to repair it because I want to keep the outboard in a good condition and did'nt like the oil leak. The leak was small - about a desert spoon underneath the outboard.  I have not asked for a quote, received an account for R4200 for the repair and parts.
5 Why did you choose the specific dealer. - I was referred to the dealer by a Yammie dealer.
I took the boat to another Yamaha dealer today.
willem wikkel spies
any oil leak on a fourstroke is problems, or for that on any motor.
i will not be happy if my car leaked oil- period
it is still unclear, thats the reason for pictures.
engines are basic and all work on the same pricipal.
so please post them pictures.
a oil leak in that region could end up lots more damage.
i hope you did not pay him, as the problem is persisting.
ss
Droomvanger
I am sure that the dealer where i took the boat will take photos.
I have described the best of my ability what happened.
The first dealer will not receive a sent from me untill the problem is resolved -and if i owes him money.
Droomvanger
Sump filled with water / oil. How did the water get into the sump / enjin?
Oil seal not properly / correctly fitted? :fbash
willem wikkel spies
but then again, the work was not at the heads
yip oil seals could have been incorrectly inserted.
not everyone is mechanically minded.
but crap like this is not excusable.
using a engine that is not 100% for surf launching is looking for problems.
times are changing, 1 of these days, you they will be held accountable for their poor service, actions etc.
ss
willem wikkel spies
droom vanger
a recognised dealer once worked on my yamaha 50 hp 2 stroke.
the enegine was opened and it was found that 1 piston was damaged on a lean run "previous owner"
ok, two crank shaft bearings replaced as well as the piston and rings.
the engine now had a noise, and the mechanic said it was piston slap.
drove the boat on nigel dam and i wasn't happy with it.
decided to strip the motor myself.
very easy, believe me.
miked the piston, 0.25mm to small
standard piston installed by a well known service provider, but the sleeve was bored out 10 thau or 0.25mm
took the block to nigel diesel
ordered new 0.50 pistons and rings.
cost 2900 for al 3.
bored the block less the r 500.
head gasket 350.
slapped everything together.
ran the motor on 30:1 oil 50 lieters.
now running 40:1
motor in tip top condition, will trust it to take me to cape town, if any rivers led that way.
were are constantly being taken for a ride by reputable service providers.
my life, and that of my family is much more.
rather service myself.
constanly checking the temp of the motor, tell tail etc.
i would rather clog up 10 spark plugs with oil then screw a engine on a lean run.
do a search on 2 stroke engines, gordon p blair, and jennings book.
interesting aspect is that the best results were, running engines on 16:1
but back to the point, oil and water dont mix. period.
they sure ********* your motors. and you now need to rust them through "surf launches"
lets see if we can get a scematic onn the engine, to see where they screwed up
ss
naks
i had a similar problem with this 100 4strk.firstly donot attempt running your engine or even starting them. if the oil and water is mixed you are going to sieze your bearing and believe me you are gonna wait a long time for spares cos each bearing is color coded individualy for size unlike a car engine.When we stripped the engine the head gasket was intact i mean it was not blown.IF THE GEAR BOX WAS REMOVED THEN I AM SURE THAT YOUR SHAFT SEAL IS DAMAGED AND THIS CAUSES THE OIL/WATER MIX.
Droomvanger
The following parts was replace just before the engine problems:
bottom engine seal
oil pump seal
dust seal
o rings  -2
gasket base
leg drive bush engine oil
The gearbox was removed in the process of replacing the above. Is the shaft seal something different than was replaced above?
Cause I still not sure how the water got into the sump?
fishalitis
Hey Droomvanger
The bottom engine seal in your list is the shaft seal. It seals the engine block off from the leg and basically is designed to allow the drive shaft to go through it. It seals off water from entering into the bottom of the engine and seals off air from entering into the crank casing.
The base gasket seals the block base where it fits onto the upper part of the leg. Here the exhausts outlets and the water intakes are often close to each other. If this gasket blows then the engine may suck water between these ports thereby allowing it into the combustion chamber and into the sump of a four stroke.
The Yammie distribututors and importers have a technical helpdesk for dealers who cant get an engine right. I would be talking to them about the ride u have had with the other dealer and it will also give your knowledge a boost. Give those guys a tinkle and ask for the techie help desk.
Having a good knowlegde of the working of your engine is a big bonus when you have a problem in the big dam.
Hope you come right boet and keep us updated.
The Owner
Thanks for your comments Fishalitis. It just make commen sence to me that either the bottom engine seal or gasket base were not fitted properly hence the mixed between water and oil?
Does the oil pump seal have anything to do with the water mixing with the oil?
