OLD AMBASSADEUR NINE :
Cuban Cigar
Was sent a bunch of reels from Namibia, amongst them, a couple of old AMBASSADEUR TEN reels and a lone, narrow spooled mod NINE.
The NINE has a broken clutch lever spring and I would really like to help the owner, to get this "oldtimer reel" going again .... can anyone please help with this little spring ?
Cuban Cigar
The spring fits under that short, black, toggle/rocker type clutch lever and then hooks through the side plate to stay located.
Cuban Cigar
Jip, working through someone who deals with the directly, on a regular basis !
Interestingly enough, becausae of the "cam-action" of this shortened type clutch lever, thd reel still functions perfectly without the spring,but you still have thd risk & worry, that you might bump the lever into the freespool position by accident !
bassbug
sourcing the original part is ideal but wouldnt another clip of similar dimensions work (as a last plan)
Cuban Cigar
That is "Plan B", but it is a rather odd little offset spring, made from much thinner gauge# wire than most other clutch dprings in mainstream reels .
Another option might be, to take one of the other ABU TEN reels and strip & remove the spring, then take to one of the spring manufacturers to "duplicate" ...
BigBen
Hi CC Have a look @ the old Daiwa Sl250H ( red line on black bakalite frame)..It has a simular spring...It just might fit.
Regards
Ben
bassbug
i opened the old sl30sh last night and checked the anti reverse pawl spring, it seens to be of thin wire and has enough wire (to be cut and bent/twisted) to make the little dog-leg as per the original
