Okuma Cedros Spinners
RANVIR SINGH
Cedros Spinners
Specifically designed for saltwater use, the Cedros spinning reels feature a rigid aluminum body and roter. Okuma's Dual Force Drag System for extreme stopping power and proprietary High Density Gearing with special corrosion resistant coating provide power and long term satisfaction in a harsh saltwater environment. Combine all this with a high speed gearing ratio and a customized aluminum jigging handle and you have one of the best saltwater jig fishing reels on the market. For guys vertical jigging, this is a dandy choice due to it's metal construction (frame, sideplate, rotor, spool) and very high drag capability.
ALC: Rigid, diecast-aluminum frame
Patented Elliptical Oscillation System
Quick Set anti-reverse roller bearing
Machined aluminum anodized spool
DFD - Dual Force Drag system
Hydro Block weather tight drag seal
Super strong high density gearing
MODEL
Bearings*
Gear
Ratio
Line Retrieve
DRAG CAPABILITY
CAPACITY
Pricing &
Selection
Cedros
CJ 40S
4 HPB corrosion resistant bearings and a stainless steel roller bearing
6.2:1
35"
30#'s max.
12#/170 yds
@$109
Cedros
CJ 55S
6.2:1
41"
50#'s max.
15#/240 yds
@$119
Cedros
CJ 65S
5.8:1
46"
70#'s max.!
20#/260 yds
@$129
surfaMIKE
Hey okumas are great reels! In my humble opinion I would rather have an okuma spinning reel any day of the week... Me like this new jigging reel:SSS
RANVIR SINGH
Im not sure if they are in SA. I saw this reel on
http://www.charkbait.com/cs/csrOkuma.htm
Whats amazing about this reel is its powerful drag system on the top model which is 70 pounds max !!!
surfaMIKE
the time when a fisherman becomes an angler is when a want becomes a need.....
I need one too!! wanna go overkill and fish for shad with one!!
mo-manack
hi guys, i bought a okuma salina 80,brilliant reel,been hammered a few times off shore by blacktips and the drag tight..i only use this reel now...i have a guy who may be able to get the new cedros,he got me the cedros rod few months back,beautiful jigging rod..i will try n let you guys know by tuesday.
