NYLON GRABS
bluespark
HEY GUYS!can anybody give advise on making nylon grabs.i have no problem with melting the lead & pouring into the mould.just that the nylon melts once poured in...nylon legs becomes flimsy/brittle, every 3rd sinker is successfully made.is there any way to prevent the nylon from melting???its a 6 oz mould with 3mm weed eater nylon
many thanx
FABIAN_seal1_
Risa22
Firts make the sinker with out the nylon for the grabs once sinker is moulded and cooled drill hols in the sinker where you would like the nylon grabs to be the add the afterwards hope this helps
FLUKE
many thanx
FABIAN_seal1_
We had the same problem. In the end the mould gets so hot it melts the nylon even before you pour the lead.
We got a Brazing Rod or S/S TIG welding rod that was about 4mm and made wires to put through it when you pour & then just pull them out afterwards. Exactly as you would make a wire grab.
Then insert the 3,5mm nylon through the hole and using a centre punch you punch just below the hole which pushes the hole closed from the bottom. This gives the nylon cord a bit of an angle up and also stops it from coming out.
soulfly
Like Fluke said. Don't waste your time drilling the lead, it is a mission and even with a drill press you end up breaking bits.
bluespark
hey gents
i use to use the wire grab mould & drill holes,punch etc n all but as SOULFLY says its was too much effort so i bought the nylon grab mould thinking it would be straight forward "insert nylon & pour lead"
FLUKE thanx for your briliant advice ill def give it a tryvvidevb
tackle whore
this is how it done commercially i dont do sinkers so am willing to share the trade secrets , to pour nylons you need a clamp on the mould and a bucket of water , get your lead melted - clean lead is a must , melt the lead and add candle wax to clean it , watch the heat - you dont want the lead red hot ,inset your nylon - get it from T-line [red heat resistant weed eater line] clamp your mould , pour the lead into the mould and dunk it into the bucket of water .Nothing will happen if the clamp is on the mould lots of steam but no explosion - dont do it with out the clamp . open the mould and take out your grab . On avarage you can throw 1 6oz sinker every 90 seconds with practice . REMEMBER WATER AND LEAD = EXPLOSION you need to keep the g -clamp on the mould if you value your face .
soulfly
By dunking your hot mould in water you will damage the mould, the sudden expansion from the heat and contraction from the cold water will warp the mould or crack it. Surely this is not commercially viable as mould will need to be replaced regularly ?
Flippie
This is exactly the way whe do it but whe dont use a clamp whe use a WATERPOMPTANG sorry dont have the english word .
whe insert the nylon in the mold clamp it with the pliers pour in the mould let it stand for 5 seconds throw it the water remove mould by hands in the bucket of water while it is still warm and hold nylon grab in hand to bend the nylon upwards.
just remeber to chance the water every 5-8 sinker you made otherwise the water gets to hot.
whe make about 1 every 2 minutes
just be carefull lead and water isnt friends and take care for your hands.
Flippie
our moulds (4 of them) is still going strong after 5 years of doing this.
maybe it is just the better metal used in the older days.
hahaaha
FLUKE
Anybody taking this advise had better read that part twice.
What you saying makes sense and would be the only possible way to pour them with the nylon in, I however would not have volunteered to be the 1st person to try that:fbash:fbash and in fact have decided to rather buy my nylon grabs even though I make everything else incl my slide sinkers.
Simen
Whatever you do, dont do the water thing, Yes it work well untill one slip, and you sit with the medical bills.
Also yes, you can pour one every 30 sek with the plastic complete without the water.
BUT-- trade secret (lol)
Koper
How many of what????:spite:spite:spite:spite:spite:spite:spite
Simen
:fbash1 sinker, complete with a capt and coke
Sailfish
Iemand gaan seerkry. Los maar die water en warm lood advies. Daai twee gaan glad nie saam nie. Kry vir jou n paar moulds en n groot yster plaat waarop jy die warm mould kan neersit om af te koel. Jy moet die nylon sinker tenminste 1min los na jy die lood gegooi het om af te koel. Nes die lood neem die nylon ook n tydjie om weer hard te word na dit gesmelt het. As jy die mould te vinnig oopmaak na die lood gegooi is trek dit die sagte nog gesmelte nylon saam. Geduld is hier die andwoord. Gooi solank twee ander sinkers in hul moulds en plaas hulle op die koue yster plaat om van hul hitte gouer ontsla te raak. Ek maak en supply meeste tackle winkels met sinkers hier in CBS. So glo my manier van sinkers maak maar. Dit bly die gouste en veiligste manier van nylon sinkers maak.:wfish
Strepie
Kaptein bly om te sien jy leef nog! PM my jou nr asb.
Jake1
Ek het gehoor die gas wat gesmelte lood vrystel is verskriklik gevaarlik, wat doen julle ouens om inaseming te vermy? Ek dink nie net die feit om dit in 'n oop area te doen is voldoende nie, 'n mens kry nog steeds van daai gasse in.
Ek sal graag jul mening wil hoor?
