Good Morning Guys
'm looking to buy a prawn pump and see you get it in Alu as well (Must be lighter as well)
Who is using a Alu. one and is it worth buying?... or should I get the S/Steel one?
Thanks for any advice.
regards
I made my own stainless steel pump using a squash ball and then flat rubber washers. It worked great but after a while it got too heavy that my arms ached. I then went over to a PVC pump with a rubber cup washer and found it to be superior to the stainless pump in that it is much lighter and sucks so hard that sometimes you cannot pull the handle when a large blob of mud is too dry or hard. My pump wore out at the front end but the tube was easily replaced. Any plumbing supply shop stocks PVC tubing. My stainless pump ended up being cut up and made into two rod holders.
