Not finding the answer i need
carp master wrote:
Help on Shark tackle.
How much line do you need on a reel for surf fishing? (sliding)
How do you target small to medium size sharks.(ones that wont run a huge distance)?
PLEASE HELP!
:ssswim:
I see the new trend is having  two thirds braid and the last third Mono.
You can not cast into deep water and target small sharks ,if it was that easy we will all be beating our P.B'S the whole time
You get the pull from what ever shark is on your'e bait first.
Get yourself a good stand up rod with loads of back bone to pull a fish and tire it before you end up loosing too much line from your'e reel,as everything that goes off has to come back on the reel by YOU offcourse .......
PLEASE HELP!
:ssswim:
now you have had advise from one the best we have ever had in this country....
Sailfish
An Alvey reel with sidecast twist wil also do the trick. For small sharks you can load your reel with .45 and have a leader of .70 - 1mm the lenth of your rod + 2 extra meters. 450 Meter wil be fine. Do make sure you have a fishing rod with some backbone to bully the shark if the need do arrive. If you have never fished and cast with a KP reel you wil have some problim. The KP reel do not have the vasillity to cast as if the reel was a grinder. It also dont have a braking system as the Alvey reels. So choose your reel carefully to avoid dissapointment from trying to get your bait a good distance in the water. I must say that a Kp in a masters hands is a great real and manny a big fish has been caught on it.
its like the lotto ..you will neva know when you will hit the big one...so rather be prepared...cause if you loose that big one...hhmmmm...you going to be pi$$ed off
Must-Byte
Wow you are either very brave or very stupid to look for your first shark on a KP! Most guys on the forum use really top notch stuff and still get sorted out by fish. Rather look at getting the proper tackle and do things right from the word go or by cheaper tackle and stick to eds for now. By not using the correct tackle you are putting the fish and yourself at risk. firstly youre going to be fighting the fish for a long time which will cause it to die and secondly a wildly spinning KP is a recipe for broken fingers.
carp master
no one like to loose a big fish, but i will keep my bait small. My trophy is a carp, for my a shark is amazing any size. The experience is more my goal i want to have caught the majority of fresh and coast line fish before i die.
carp master
Thanks, i like my fingers. I love seeing a healthy fish swim off and survive even more. i will do mostly eds fishing that i will put back.
carp master
P.S i like to think half brave half stupid and an extra half extreme. The 1st time i ever sore shark fishing was when i was very ignorant. But after seeing this guy pull out a 180kg monster with what appeared to be a deep sea reel. what can i say it was the birth place for an adventure.
The joy of fishing in the Ocean is that you could catch anything on your next cast.
2 of my most memorable catches came from small baits -
173kg Bronzie when I was casting a small river mullet to get a hammer for a swimbait
145kg Zambezi on a nice Chokka bait ment for a Diamon at Mtunzini (20cm bite trace)
If your budget limits you then use a small bait on a reel with line matched to the rod and reel.
When King Neptune sends one of his Denizen's of the deep to taunt you, enjoy the feeling of absolute brute force and then be prepared for our fixation of saving and buying the right rod braid etc, etc, etc so you have a chance in future.
My advice, if you can get the right setup from the get go or be prepared to be smashed and humiliated in public. Furthermore it'll be better for the shark if you have the right gear from the beginning.
Tight lines my friend
carp master
I know what you mean about get ready to spend part trust me.
My in land goods could have paid off a small car by now.
That is very nice you had a chance at those fish.
If you went lighter chances are you will loose your line, is that not dangerous for the Shark?
Best case scenario is that the rig breaks or it breaks on the leader then the shark will shake out the trace in a few days.
Worst case is it takes all the line and ends up with 400-600m of line trailing it and if it has rolled itself into the leader then it may not be able to swim and eventually drown
JL
PLEASE HELP!
Maybe I can help on this question as I have only caught small to medium sharks, whether I want to or not!!!
Go to a nice deepwater point, put a whole sard/mackie/chokka (or combo)out and wait!  If you want to ensure that you mainly get picked up by small/mediums, fish at places with shark nets like Scotties point.
My 2c
And what about those huge Ribbontails, Diamonds and Honeycombs that hang out there? I saw a guy landing a Ribbontail there of 141,5kg's (on small bait) and more guys losing their fish after a 4 - 5 hour fight. Fact is you cannot ensure anything by putting a small bait out and fish places with shark nets. And yes, I know you said MAINLY, but you should be prepared for those eventualities of a monster picking you up, being equipped with the best possible gear, and not a Magnum Freshwater reel and substandard Rod, not to mention your line and other terminal tackle.
carp master
I think ill Stick to my eds for now and ill make trip next year focused on only sharks. Thanks for the help every one!
Question, with the shad float trace are you men't to let the float surface or keep it down and just off the surface. This is more on the surf side of things.
strandloper
PLEASE HELP!
My 2c
True JL,
Hence the reason S many guys still consider Scotties to be one of the best in-eds spots on the South Coast.
Even more true about the set-up, rather go for an overkill than inadequate
