NON ED ROD
Mike Pike
Sorry guys posted this but it never got thru . so here we go again .. what do you use for non- eds tha has got good pulling power and backbone for "heavies" i currently use a Beachmaster ,standard,trigger winch with heavy tip rated 7 oz sinker ... will this do the trick if i hook something with pulling power and weight ? what else is there that wont break the bank ??... L/F sharkey ? Shimano exxage ? what you"s recommend ?
Tsa
No one? I am also in the same situation Michael. Any suggestions guys? I am leaning towards the Sharkey.
Mike Pike
TSA i agree ,there"s some serious rods out there for non eds , HMC, HMG, which are really good but quite pricey ... would be nice to have one dedicated rod for non eds that does the job /wont let u down , the L/F Shakey seems to be reasonably priced ,xcept u have to change the guides, but apparently the latest version is comming out soon with larger guides and in hmg ??? dont know will have to keep n the lookout if they appear on our shores .
Tsa
Yip - the hmg model does sound good, but from the sounds of it, its close to double the current std model's price.
Mike Pike
TSA, looked at the Shimano Exage AX SURF 1468 6.7.8OZ tips  can get them for R1154.00 at tackle2go in centurion , will look at maybe that option and ask around what other members think of them .
Tsa
Heya MP - I see NEWAD97 has also mentioned the Exage. I compare that closely with the L&F Custom I currently have, so was looking for something with that bit more backbone.
I guess I have just made up my mind - its going tobe the Sharkey. Just try to get the best price on it.
Psy
Depends what you will pay?! Rod builders here on the garden route have very good quality sticks, loads of shark fisherman here too. Take a drive to George,visit Xtreme Fishing & Tackle Trader.
Kumz
Mike Personally i wud say if you have the $$$ ..
Pentagon HMG Heavy ... you must try Hooch's out !!!Next weekend !!!
Hooch
If you do not want to bust the bank, ill recomend the Poseidon 3XH. It has 16mm guides already fitted and can cast 8 to 9oz sinkers easy. If you have the $$$ then like Kumz said, the Pentagon HMG Heavy. Mine has the short heavy tip with 16mm titanium guides and its 13f 5inc in lenght. Just be advised that this rod can't cast anything less than 9oz. But sadly, it will set you back R3400. Mike you are welcome to test my rod at the social. I already converted skrops to buying one and im sure it would't take mutch to convert you as well. LOL
Weedeater
Mike,
I would recommend waiting a bit and going for the Pentagon Shark Extreme from Gremlins, if you want something with serious pulling power and backbone. I spoke to Rob about it a few weeks back, custom built it'll set you back about R2800, which in my books is well worth it.
Hooch
[color=#006600]Weedeater[/color] wrote:
Mike,
@ Weedeater
I spoke to Brendon about two month ago when i send the rod down for some mod's, were i asked him what the differance is between the Pentagon HMG Heavy with a short heavy tip and the Shark Extreme were his reply were not a hell of a lot apart from the shark extreme that is 5ich shorter than the Heavy. Do you perhaps have different spec's? The Standard HMG Heavy is about 14ft6inc were mine is shortened at the base by one foot for extra pulling power. The quote he send me (For insurance purposes) clearly stated R3400. That price you have is a seriously good price.
Weedeater
Mike,
@ Weedeater
Hi Hooch,
I spoke to Rob about it, that was an approximate cost but from he told me, the Shark Extreme has less T53 graphite in it than the HMG Heavy, hence the price difference and stiffness - he didn't say what the rest of the blank was made up of, I can only assume T24?
It is definately shorter than the HMG Heavy, 13ft 6" something as far as I know.
Hooch
Thanx Weedeater. So My rod is actualy shorter than the shark extreme. I think T24 would be the right composition that Rob spoke about, hence the price differance. Thanx a mill.
Mike Pike
Thanks for all the input guys... hmmmm i"ll have to put on the thinking cap on this one but will check all the options out and see what Santa stuffs in the stocking !!!
@ hooch and kumz thanks dudes will try them out on 22/11 ::slo
I'm also in the market for new rods. And the more I read these threads the more confused I get. It is more difficult than finding your dream wife. The onlu difference is in this case I'm the one thats getting the headaches.........
Mike Pike
bamboes vis , u should pop in at the social to get ore info on the various rods... ther are some pretty talented guys out there with some good info and insight  in all aspects of tackle and angling , u go to Kosi often  ?
I've only been there once...........but it was definitely not the last time. I was trying to organize a Kosi trip for December but all my buddies bailed on me. So will definitely go there March next year. I really wanted to join the social but I already made arrangements for a bit of pap gooing at Dronkwordspruit this weekend. But if it gets cancelled for some reason I will definitely join, I mean what would Deisel and his guitar be without a lead singer?????
