Night fishing for Bass
nico carelse
jy is redelik gesort.
Maak n draai dan wys ek jou waarna om te kyk.
as die tackle reg is en die tegniek is reg dan moet jy vis kry
nico carelse
Never loose faith in topwater.
the most important thing about Bass fishing is that you must have 500% faith in what you are using to catch fish.
This is the one and most important thing. Then the rest will fall into place.
Just a few basic rules.
1. Clear water = natural colours
2. high water temps = late fishing structure with drop-offs
3. If they are shy go light and wheightless.
AND HAVE FUNN :fbash
nico carelse
Hey man Bass fishing is not rocket seince.
stick to basics and have faith in what you use.
No faith = no fish.
Astrix
:wfish
Dis so waar glo in jou toerusting en vertrou dat die vis daar is, aanhouers wen as dit by hengel kom.  Dis my vriend se groot probleem hy raak heeltemal te gou moedeloos as daar nie 'n byt is nie.
Monster
Try a black spro popping frog next time you fish at night. If your heart is still beating after 20min you should be fine.
Monster
nico carelse
::S
That I will do.
will it have the same result as a crazy crawler with the barbels.?
They just cant seem to leave them alone they have broken 3 that I had to replace in the last year.
J_Bay
I remember the first time I tried to go for bass at night. I was using a Hula Popper, and I heard a splash and gulp, I figured it must be "for me", so I wound up and hit it, and that yellow popper came shooting out like a little rocket!! Luckily I managed to evade it...
I agree with Nico, no confidence means no bass. They're actually fairly easy to tempt, because they're so aggressive, except on the days when they get "lock jaw", but still you have to fish with confidence!
