newbie at bait casting reels
thornza1
Hey guys,
I just bought myself my first "bait-caster" (or whatever those hard to cast reels are called) yesterday ( a Daiwa 50 Fire something or other - basically a starter reel just for me to learn the ropes on).
I just can't figure out what this one little knob is for - it's below the drag control (the big star shaped thing) and looks like a little silver round metal thing that you can turn tighter or looser. The manual says that it sets the spool end play or something like that. What do I use this for??!!!
Anyways, I was casting Ok for a first timer I guess, not very far and only one really serious over wind at the end of the day that I had to cut line to get rid of! The problem was that when I was controlling the speed of the reel with my thumb it started to burn really bad and I had to take my thumb off the reel and then I got a HUGE mess. How do you guys not burn your thumbs or do I just need to toughen up a bit??
laters,
thornza
brendon muscat
That lever is to tighten the spool setting, Try tighten the spool so that there is just a touch of play and then try casting again, you should only have to touch the spool ever so gently to slow it down.
Homie
Hey Thornza,
Firstly, please fill in your location. Thanks bud.
Ok, Its a Multiplier reel.
The knob you mention is the spool tensioner. It controls how fast the spool spins.
For a beginer, set the knob on tight. This will reduce the overwinds.To test, Hold the rod up with the sinker drop you prefer, and let go of the spool ( as you do when you cast) when the sinker hits the ground, you should have only about 2/3 coils loose around the spool. You can loosen this as you get more comfortable.
As for burns, try to use your thumb on the side od the spool, and wet the line with clear water. Apply slow pressure, ( feather) rather than a quick downward press.
I also only recently started using a multiplier, and know exactly what the thumb feels like.
hope it helps
Maestro
Perhaps a 50 reel is too big esp for a novice with multiplier reels, you want to be idealy using a 30 or 20, esp if you are fishing for edibles,but i guess that the salesman 'forgot' to mention that to you...practice makes perfect so head on down to your local dam, tie on a sinker and let rip all day long, and you want to aim for height rather than distance when casting.
