New Rods
[color=#006600]Hooked[/color] wrote:
I cant change my avatar , ive tried!!!!
Just make sure you delete the old one first... then upload the new one. Give it an hour or 2 and it will take effect! For some reason, new Avatars take a while to take effect. I think clearing your Internet cache afterwards might make a difference too.
What flippin rods are they????
Poseidon
k k k, MAYBE a doff question, can someone please tell me whats the purpose of having a butt like that???
scorpion
in the uk the guys use 13-14 ft rods with small reels like abu 6500 and daiwa sl 20 and 30sh reels. you must mean the portuguese and the spanish. those are continental style rods designed to fish with coffee grinders. those rods are for match fisherman catching fish like pouting and codling whiting and mullet.
Hooked
Just took the one out for a test drive.
Loaded up a Okuma Beach Master .45mm mainline and a 1.0mm leader.I am so happy.I was hitting 115m with 6 ounce and when I went up to 10 ounce the rod just came into its own zone.I paced off 1 cast at 145m ( 1 stride at 1 meter , not very accurate , but close enough for me).The only prob was the ten ounce sinker hits the ground so hard it drives itself under.Had to do a lot of walking and pacing.Dog can walk itself tonight.
Pylstert
Simply a different casting style, the Europeans and UK like to control the reel with their right hand.  *&^%$ knows how you reel a big fish in with that set up, can't think it's comfortable holding the but under your arm for 2hrs. you certainly can't use a bucket with it???  in the UK only the competition casters use their reels at the bottom. you are seriously going to look like the ultimate Vaalie Hooked, fishing for Bronzies with those Leeukop Dam rods, reckon we'll all have egg on our faces if it works though, but I also reckon be careful of getting that long butt up your butt, it looks dangerous :D:D:D.
MAC
Yeah, over here 15 foot rods are very common. I have a 16 foot one myself. I can fish multiplier or coffee crinder.... Depends on what I'm doing. If you are fishing multi you just use your right hand to grip the spool, easy once you get used to it.... The only problem I can see when using these for big fish is leverage. Your arms and shoulders will get tired quicker, with the increased strain from the extra rod lenght. Over here we would be lucky to get a 8kg fish on such a set up so we don't have to worry about such things...
The extra lenght sends the lead through a bigger arc when casting, even with an overhead cast. With the lead moving through a bigger arc you load the rod more and you tend to get bigger distances.
Kev
Hooked
Hi Mac
U guys got anything with a 13 ounce cast weight and a line weight of 20-60 lbs?
I figured I would plant the reducer in the ground a work the rod from the floor if I got anything big.
Ive landed a 15kg carp like this and it wasnt that much of a struggle.
Hooked
Thing is I got two 16ft graphite rods that gets distances with say a 10oz sinker of 200m + (no lies, i've had to up my leader to 40lb otherwise snap-offs due to the casting power) but this distance is off the nite-hawks i used for papgooi-ing, also never strapped a coffee grinder to them.  So now I'm thinking of getting some grinders for them two rods and perhaps drive down with the cruiser in stead of the golf (more tackle can fit on the cruiser).....:spite
:f1shy
200ts
Its a centre pin reel, whereby the spool disengages completely so you can cast it out like you would a coffee grinder.  LGF, you must have had fun reeling it in from 200m :D
200ts
Bud I had some serious carp's taken me on that distance and worst of all is this happened at places like Bloemhof, where you get a decent sized fish running every 15min on using the wrong bait..... your arms feel like falling off if you get to net 98 fish in 10hours all weighing around the 2,5-3,5 kg mark all running the reels with the bait at at least 200 meters. thats why we only used to go to places like bloemhof once a year.... get some bi-cep improving excercises......
@Hooked, bud we'll be goin to Margate for around 3 days perhaps 4 and then its off to PE's side of the country. Btw, here's a pic of said Nite Hawk Centre-pin reel.
Used to be used by just everybody that did pap-gooi-ing back in the day when i was still into that facet, mine was blue thou.  Rigged with 0.19 mono and some 2 and 1/2 rods legths of 0.45 leader and some technique that involves a little swing in the bait, dangling about a meter beneath the rod tip a step forward and some serious graphite composite testing whip of the rod and there she goes........
:f1shy
Bud the reason for that extended butt section is purely to increase the power to the rod during the Over-the-shoulder casting technique, hence it's termed a Power-butt.
It realy supplies you with that extra legth of leverage to excerse so much more when swiveling the rod at the reel seat, so basically the arc at the bottom of the rod when casting had a far more smoother motion and allowed you to really puul that piece real hard whilst pushing the rod foward with the other hand, result? mielie-bom, weighted, travels 200+ like nothing, especially using thin diameter line and the centre-pin Nite Hawks.
:f1shy
Guys
That 16ft graphite rod with the power-butt, hanging in the lapa......... I'm thinking of strapping this to it and mix it up a bit with an over-the-shoulder cast as I used to do, perhaps not with braid as that technique has a very high whip like action which is something (I tend to think) braid doesn't like all that much.
anyhows here's a pic of my ideal reel for this crazy notion......
The Shimano Stella 8000FA
:f1shy
