new project
HEIHACHI
i have just aquired this golf cart::S(pics to follow) it very dirty i know but otherwise everything works great, its collapsable, its made of alloy(only have to worry bout rust on nuts and bolts), it has quite a few bags already all functionioning(do i keep them or do i attach my orca style bag to the frame?) any help, advice, pics criticism all welcome. lets make it a sealiner effort we could learn from each other and maybe the next guy building one will already have the ideas available.
come sealiners help a brother from another mother:wfish
Kumz
Personally i think you will have to go on a trial & error basis ...
Check what you wud carry ... & try to make it fit ..
But you dont want to make it to beeg & heavy ...
On_Dad
Remove the bags. Use 2 tubes attached on sides for carrying rods/ baiting up. Modify frame to be able to attach tackle bag at the top and chiller at the bottom. Add on a removable tray if you want for sinkers/ odds + ends. Leave it to be foldable. Maybe trim the height off a bit after measuring enough space for above.
My 2 Zim dollars
HEIHACHI
ya andrew dats my ghillie but the only things he carries now is his nappy bag and his dummy!
shot for the input guys!
you think the wheels will be a problem on the sand?
Yep Hachi... I would agree with Possy here... I would strip the cart down to it's frame and then design from there. Those wheels...? Hmmm not sure whether they'd be much good in soft sand... So before you start, test it on the beach in soft sand with different weights on - that might save you a bit of heartache.... On hard sand, all the carts work well, but as soon as you're above the high water mark, things change very quickly and you end up dragging the thing through the sand... big mission! The only wheels I've seen work really as they should in thick sand are proper inflatables... 2c
Mike Pike
Hi Heihachi, i modified a golf cart a while back bit different make and design to the one u"ve got , u gotta sit and think it thru carefully,how u gonna change it without compromising fold up concept and strength if u just gonna carry the tackle box and cooler box use there size as a guideline to how and where u going to modify i have"nt tested mine yet in soft sand but will soon , if u do a search there were a couple of pics posted on my attempt "modified golf cart " check it out and have fun , use you:re imagination you"ll be surprised what u come up with ,cheers Mike:cool:
Echo7
Bring the thing here this weekend, I'll help you get it cleaned up and modded. I have a fair amount of experience with wheels on sand!!
Call me 2morrow, cheers.
