New Multiplier Reel- Braid or 'Normal' Line
Longname
I'm thinking of buying a Trinidad 20 DC (edible fishing), and would prefer to go braid (can get 700m 50 pound on the 20 DC) , but would love to hear from the experienced surfcasters
Keep in mind that the DC assist with the casting, so little braking is required.
Advise will be appreciated.
Mangi
Send Hannes101 a pm. He has been experimenting with straight braid on a multiplier for R&S fishing. To my knowledge, he has not lost a finger yet.
deezynking
vey important...very very important. i know a guy who was used to spinning with mono and slit his thumb one day on braid, needed stitches coz one day he forgot he had braid on and not mono.... but this was on a grinder reel.
Elf 786
try using this link. LINING THE REEL , braid of what i heard is quite expensive and i am actually gonna try what was said.
oh yes u have he longest user name than any of the 12,000 members , well done ,lol....
Longname
Thanks. Fortunately I've been fishing for a long time now with braid on my grinder reels, and very early on learned to keep my fingers out of it's way. Try saltwater on a 'paper-like-thin' braid cut while the fish is biting. I now carry by default a couple of latex like plasters, which last long while being immersed in salt water.
Best thing though is to use the Breakaway Cannon (bionic finger) on a grinder reel. Hugely improves your casting distance, and release control. HUGE improvement.
Longname
Elf, thanks, that was exactly what I was looking for.
Spoke to Landshark today, and he gave me the same reply, but his reason for this was quite interesting. He tried the braid on top, and while the first couple of cast was brilliant, and quite far, the more he retrieved against little more than finger resistance (obviously fish was not biting. Mmmm maybe he was at Arniston..), the less dence his packing of the braid on the spool. Result was that after about 5 casts, the braid started cutting into the now less dence braid below. Big mess. That confinced me, as this makes sense. Easy when you pack the spool with some help for nice resistance, but more problematic when fishing R&S in the Western Cape.
I've just started with 300m Power Pro 50 LB, and will then follow with hopefully 200m mono (30 LB 0.50mm) and then Fluoro leader.
Long name is a long story (no pun intented). Fired the useless fishing gods (wanted 15% increase, and I can only afford 2%). Apparently, they are now working for Eskom. I'm solo now, but cant change the name anymore......
Marc Rubelli
Straight braid onto a multiplier generally a bad idea. Remember that the softer or stretchier the line, the better the cast. Braid = No stretch = poor cast. If you are looking for a high response line, try a fluoro coated line like power steel. . .
Loams
How so? I only have braid on my Bass kit, and I cast further than when I had mono on it. I understand its on a multiplier, but I am trying to understand why
action man
heres my advice...use it dont use it!
instead of buying the DC i would rather go with the Ultega 14000 filled with 50lb braid. my reason for this is cause you would cast alot further with braid on a big grinder as the surface area on the spool is bigger than that of a small multiplier and the line flies off alot easier (tried and tested so dont argue). This reel is super strong and alot of club anglers in KZN are going with this set up now. And to be honest you dont need 700m of line for edible fishing, guys here have been landing diamonds and honeycombes over 80kgs and havnt had any problems...if you want me to explain in further detail give me a call on 083 775 7687 or give me your number and ill call you
Longname
Action man, thanks for your reply. What you say makes sense, and you'll definitely cast a lot further with the bigger spool.
My reason for the DC is actually the Digital Cast control itself. I can not cast with a 'normal' multiplier, and for the little time that I get to spend fishing, I prefer to concentrate on fishing and not freaking out, with the fish biting, and me sitting with a lovely 'kraaines'. Life is way to short......
I've been fishing all my life with fixed spool reels, exactly for the reasons above. I have them all. Big pit, baitrunner, long cast etc. etc.
BUT, the DC now allows me the ability to use a nice multiplier, which I can use straight off, without the frustrating learning-curve normally associated with multiplier reels.
Longname
Loams, I agree. The feedback I had from Landshark was that with just braid on, his cast was a LOT further than with mono.
On my fixed spool reels, I only use braid, with a short fluoro leader. There is NO comparison on these reels between braid and mono. You'll cast WAY further with braid. Guaranteed. If you want to cast heavy lures or sinkers on fixed spool, invest in a Breakaway Cannon. You'll simply be amazed by the additional distance, on top of the increase that braid gave you.
action man
The only problem i have with the DC is that if you have the cast control set on high you will lose so much distance because of the resistance the chip is putting on the spool to stop the overwind...you still have to control your spool with it, you cant just cast and ket go, you will still get an overwind!
Trust me i tried it...it is a dam good reel, no doubt about it but i still say maybe borrow a friends multiplier and try learn to cast with that...just now you spend all that money on a reel and you dont ending up liking koz you snot getting the distance you want...
Can get you the DC at a good price if you still want it
Longname
Action man, thanks for the advice, but for now I have to make it work.
I already bought my 20 DC, at a price that I would rather not publish here. No it did not fall off a truck.. LOL Legit tackle shop.
Once I've mastered the dark art of multiplier-casting, I shall definitely look at a 30 for my 14 ft. The 20 will for now serve on my 11 ft HMG, and 14 ft.
If you could possibly get a 30 DC for less than R5000, my other fishing mate (experienced caster, using 'normal' 20 Trinidads) want to add a 30 DC to his arsenal, and I think he will be very happy....
Murdoch
Here in Aus I use 2 Daiwa SL30's for spinning and poppering. One with 30lb braid and the other with 50lb. Never had a problem with either of them getting the braid cutting into itself or my fingers getting cut. This is with me casting 100+ casts a day.
I can now also cast alot further than when I had mono on.
Longname
I'm a believer in braid, simply because of it's ease of use, nice knots, and the awesome distance I get when casting my fixed spool reels.
With the multiplier though, I'm still very much in a learning phase.
Will practice for now with braid on the bottom and 200m mono on top.... a lot cheaper if you've got to cut of 200m of mono, rather than braid! I know....:doh
What rods do you use? We are not exactly spoiled for choice when it gets to surfcasting and surf spinning rods.
Murdoch
Hey there,  I actually use a South African bought rod.  Elbe Waverunner 3 piece.  Have spun up 10kg+ spanish mackeral (couta), 20kg GT's (Kingfish?) all the way down to our tailor (shad) from the rocks.  Very nice rod and depending on the conditions I will use the sl30 with 50lb or 30lb.
Longname
Thanks Murdoch. Will go and have a look at the Elbe.
