New guides
Nick
I am needing to replace some all of the guides, except the tip on my beach master. I got a quote from a nearby tackle shop and they want R450 to fit and supply.
Has anyone done this by themselves as I dont have that kinda cash to give away. Id love to do it myself if possible or get it done somewhere else at a cheaper price.
Mangi
Doing it yourself is a lot of fun. Check out Reefmans post under the DIY section on how he did it.
Check out Khan's website for guides, good prices and great service: www.rockhustler.co.za
Riaandl
Nick, it is not that difficult. The only thing that is rather tricky is the epoxy. do a google search on rod building and guide wrapping.
dup-zn
Hi guys
I also recently got a shock when i took my rod in for guides. its rediculous!
My ballie and me have started this past weekend to build a rod wrapper to suite our rock and surf rods.
We have 32 plus rods so new guides will cost us a fortune.
We are doing the final touch ups and i should have pics available later this week.
Here is some of the info i gathered.
FLEX COAT is the way to go as far as epoxy that covers your binding is concerned.
As for the cotton you should look at the following brand GUDEBROD. With the aforementioned cotton you do not need a "thread and colour sealer". It saves you on drying time.
If you have three piece rod your setup will be considerably smaller than the one i biult.
will post pics soon as well as some plans for smaller wrappers.
I do rods all the time and have 40 odd in the warehouse to be done.
Yes you can do it yourself and you can also make a mess yourself but the sense of achievement is great.
To do single rod you don't need a machine setup all you nee is a large cardboard box wit 2 x V's cut in the top so your rod can rest there. Start turning at 2min intervals then 5min then 10 min and in 1.5 hours leave to cure.
I also want to come out in defence of the builders here (I am also one)
The guys who will do your rod will not only strip the guides but clean up the whole blank and re-spray it
They will then supply guides (R100 - 300 per set depending on type)
Bind and then epoxy the guides.
Flexcoat / Gudebrod / Laquer (2 part hard) around R60
Labour total of 3 hours (rod condition) at std rate of R100 per hour (What does your mechanic charge when he services your car)
Thats where they get the standard rate for full clean, respray and fitting of guides of R450, they'll probably clean up the grips as well
We do the job for between R350 - 450 per rod depending on the rod condition, type of guides and style of binding requested
Just remember they're not doing it as a hobby, just as your mechanic provides a service of servicing your car so he can earn a living so is the rod builder, tackle shop providing a service to make a living. If he doesn't strip and spray everything himself he has to pay someone to do it.
@Dup if you need, talk to me about guides aybe I can help you out like you did for me with the sinker mold and wires.
dup-zn wrote:
Hi guys
Why don't you make the idle end on a slide. Build a frame with 20mm square tube and fix the idler end and motor end on 25mm tubes. They can then slide up and down giving you what ever size you want. Thereby not limiting you in the future.
Then if you are using it to wrap, you can move the idler to the guide so you can put pressure onto it.
I just made the brackets with a motor for Reefman but never took pics. Maybe he can post a pic of it when he gets it.
Nick
Wow thanks for all the info and help guys. Im really keen to try it myself. Will let you know how it goes and try to document the process. Thanks again,
Nick
Arno Nel
Well said Enigma.
As jy van jou stok hou en will he dat dit ordentlik gedoen moet word dan moet jy bereid wees om te bettaal.
Gaan loer volgende keur wat hulle jou vra vir arbied as hulle jou kar diens en kyk maar na die hoveelhied tyd wat hulle op die kar spandeer
LEON S
Have a look at this, if you havent found it yet. I am doing one tonight, will post the pics once Im done, if it comes out allright........
http://www.rodbuildingforum.com/index.php?showtopic=16216
