New fangled pulley rig
Hooked
Hi Guys
Ive spent a bit of time thinking about the pulley rig.I know this rig works for a lot of peeps but I have been experimenting with it.
Hope this pic comes out all right as I only have paint to draw with.
The basics of this rig are.
1)The pulleys give the fish a mechanical advantage over the weight ie the fish will feel less resistance.
2)The opposite works true as well.When striking your power reaching the swivel will be doubled.
3) When you have a fish on , your sinker will be lifted clear of the ground.
4)Hopefully by feeling less resistance the fish will swim with the bait and hook itself when the pulleys close.
Just having some fun on a slow day.Comments appreciated.Anybody of a mechanical bend please note that this pulley system should be concidered as having free axle.Therefore the mech advantage is 2
Emperor
Administrator
Bmp images are supported as attachments. make sure that the image width does not exceed 600pixels. max file size = 3500000 bytes.
Files with the following extensions are supported,
bmp, gif, jpg, jpeg, png, txt, pdf, xls
If you are still experiencing difficulty in uploading an image, email it to admin@sealine.co.za or get in touch with Reefman or Landlocked.
Silent Bob
here is a better paint program:
http://www.getpaint.net/
and if u need to photoshop the size of your fish but photoshop is too expensive:
http://www.gimp.org/
Raggieman
To complicated just run the line throw the three way Swivel and and taach one enf to the hook trace and the other to the sinker by having double line to the sinker can result in the whole trace becomng tangled up
