Designed for bullet-proof reliability while trolling, these rugged reels will also cast live baits like a rocket for Tuna and dozing Billfish. Load them with mono or braid and there isn’t much that swims they can’t handle.
Saltist® Lever Drag 2-Speed Big Game Reels Features:
Fast, One Touch gear shift
Precision stainless steel gears
Seven CRBB corrosion resistant ball bearings
U.T. Drag system with dual carbon discs
Infinite Spinâ„¢ free spool for maximum casting of live baits and hardware
Main shaft bearing stabilizer prevents excess side pressure on spool bearings regardless of drag tension
Aluminum frame and left sideplate are one solid piece for unmatched strength
Zaionâ„¢ corrosion-proof drag lever
Rugged, dual point gear shaft support
Machined aluminum spool
With aluminum rod clamp
