Killy.
If i understand you correctly,the little silver ratchet selector activates when you cast ,basically to go grrrrrrr whilst you casted.
To sort out that problem is quite easy,you remove the 5 screws from the back plate(The side of the ratchet).Inside there you will see a brass round ring and to the one side there is one screw that holds that all in place.Its difficult to write this but let me try and explain.You will see their is a little thing its heart shaped more or less that is situated between two parts of the ring.Loosen the screw that holds that all together and move the heart shaped thing as far as possible out of the ring,this is a very little movement and will be the solution to your problem.Tie it up again and whala...
If its not clear for you pm me with your cell number and i will call you!
Frikster
