Naby-Kolhengel VS. Afstand
Brakkanjan
Ek het by Koppies met die Social gesien dat die Karp baie diep was (Die mooi Grotes).
My vraag is as volg? As ek bv. by enige dam op ongeveer 60-80 meter 'n goeie kol kan bou en die kleiner vir begin byt na ander aas soos Mielies of n trossie wurms gebruik om groter vis te kry ipv maksimum hengel afstand te hengel
Mense het ook al gsese dat geure soos tcp of duiwels kleiner vis weghou maar ek het al baie klein karpies ook gevang met daai geure
wat dink jy
:breakd:
Carp hold on Thermoclines and the larger carp in the most dams are found in 4-8m of water in daylight hours so if you want to catch bigger fish
Deep Water fishing
Long line fishing
Having the perfect bait 100m away from the fish will not get bites but the wrong bait amongst the fish will get the bites and the right bait at the right depth will get the fish
In short the distance from the bank is less important than the depth of water you are fishing in (99%) of the time.
It all has to do with the temperature of the water and the deeper it is the cooler it is, this is ideal for carp which are temperate climate fish and they love 14-18 degree water.
Also the temperature fluctuations in deep water are less than in shallow water and being cold blooded the bigger fish adapt slower to water temp changes so they will keep in deeper water in the day and as the water over the feeding grounds cools at night they will move in closer
this explains why cast baits get bigger fish at night than they do in the day
Waldok
Ek dink vir kompeterende hengel is kolgooi belangriker. As die vis op 60m uitkom, en teen n redelike tempo, waarvoor moet jy dan dieper gaan. En met die nuwe reels kry jy punte vir elke vis in elk geval.
Sosiale hengel, kan jy maar diep hengel vir dir groot menere, jy mag miskien net n paar biere wegkap terwyl jy wag.
Naruto
maar die kanse dat jy groter vis ga trek na jou kol toe is maar baie skaars. Ons het al n naweek gaan hengel en net staat gemaak op kolgooi en die grootste vis wa so 3.5kg. Dis baie selde dat ons al vis (nie baber nie) oor 4kg gevang het, self op afstande tussen 120m to 150m by die vaal.
Jaco_Jaco
Hi Brakkanjan,
Ek glo maar soos vis ouer word (soos mense ook maar) leer hulle sekere dinge en gewoontes aan, en daarby saam hulle "comfort zones". Soos Enigma tereg sê, groter karp raak baie meer "finicky" oor water temperatuur en die dieptes wat hulle voorkeur.
En alhoewel die groter karp in 'n dam rondbeweeg is hulle tog redelik "Territorial" en die roetes wat hulle volg is diepte en struktuur georientëerd. Dis waar hulle oor baie jare gemaklik en veilig leer voel het.  Hulle sal nie sommer van die roetes afbeweeg nie maak nie saak watse aas jy na toe verander nie. Maar daar is altyd uitsonderings en elke dam het seker maar 'n groot vraat of twee, maar in die algemeen moet jy na die vis toe voor die vis na jou toe sal kom. Kleiner vis is baie meer versatile en swem oral die hele dam vol en sal na die kos toe kom.
Dis juis hoekom "watercraft" en baie navorsing en huiswerk huiswerk in spesiehengel so 'n belangrike rol speel.
Brakkanjan
Dankie weer aan almal vir hul insette, Jaco ek het al in die boeke gelees oor die roetes en wat jy se maak vir my sin. Ek dink dis hoekom julle spesie ouens sukses het omdat julle baie navorsing doen met fishfinders oor strukture ens.Julle gaan soek die vis (Nie soos ek nie, kom by die dam aan en gooi! :::S  )
Enigma, dankie vir die inset oor temperatuur, ons temperature begin nou verander en in die oggende is dit al lekker koel.
Ek het eenkeer 'n kompetisie by Steyns gevang waar 'n karpie so groot soos my hand 'n groterige Daichi hoek met twee Vaaldam pitte gevat het. Kleintjies eet enige iets.:wfish
pumamangp
i agree with Jaco-Jaco and Enigma said
temp and depth and water clarity and structure and ground/bottom composition and comp for food, all play a part, some more important then others.
fish feed where they are used to getting/seeing food, where they feel safe, where natural food occurs. they dont just swim around all over the place, they stay in their safe zones.
the compositon of the bottom is important as from this you then know how to present your rig/bait what bait to use etc.
water clarity is also important as the sunlight can only penetrate a few meters under the water depending on the clarity. plants and organisims need light to grow and live. plants grow act as food for fish and home to bugs etc, fish eat bugs etc. you starting to see the picture
we could go on about each aspect for hours and each one has its own importance and relevance. the bottom line is find the fish, structure, safe zones and present the right bait in the right way, etc and you will have a gr8 session.
thats just my 2cents
Naruto
If you giuys want to read something realli interrestiing, go to the bass section and the the sticky about fishing the channels in a body of water. I think it holds true for most venue and fish: http://www.sealine.co.za/view_topic.php?id=26855&forum_id=32
The reason the bigger carp hold to routes is that the water temps remain rather constant
It is also for this reason when all of a sudden in certain times of the year, normally late April to end May that many more large carp are caught at casting range in venues where they are normally scarce.
The rerason for this is that with the water cooling on the surface there is a point of equilibrium where the margin water is similar tin temp to the deep water so the change in temp is minimal bringing the larger fish into casting range and in all hours of the day and not only at night.
If you think about this you'll soon realise this is why Rietvlei in May delivers many good fish as with the Vaal in casting range.....
I agree fully that in competition that kol is important but with the change in rules a 2kg carp is worth 4 small carp or 4 small muddies so the idea of fishing points changes and this was totally evident in the GN leagues where guys with 5 fish took out bags of 9-12 fish and this in the Vaal
The Munt club absolutely dominated the league season and their full strategy was big fish and their bags average 1.4kg a fish in many cases giving them a monster advantage
I saw it at the Nationals this year my average was over 1.2kg a fish and every day I beat guys with as much as a 40% better total of fish but not the weight
Oom G
Enigma,
I agree with the fact of water temp....makes sense and will def be remembered apon next excursion...:)
All the info though are applicable to dams...right..? What about flowing water, like the Orange river bordering SA and Nam....? We catch big Carp here....last year the ave weight was about 5.5 kg with the biggest being 11.05 kg. ( PB was 8.00kg) But not a high amount like you would be catching in dams per occasion.
According to you, how do you differenciate where your flow of "climate perfect" water for the carp would be and do you think the best area is in the edge of the flowing water or at the shallower still water?
PI
Enigma:
How will I then go about catching bigger fish when my average is only about 700gr?
1. Do I take time during the comp to cast out my depth measuring float or do I just cast as far and hard as I can, assuming that the water further out is actually the golden 4mtrs mentioned above?
2. Do I sort of adapt a specimen/carp angling baiting approach..
PI
