My new surf spinning rig
BluFlu
I MUST stop looking at Gumtree.
After Christmas popped on to see what was lurking in the classifieds and lo and behold a Van Staal VS 150G (right hand, bailess) was being sold just down the road from me. Just wanted to look but when I held the little beauty in my hands I knew she must be mine and she is.
So what to put her on? Decided to pop into Fishing Specialist to take a 'look' around and yes, lo and behold they have two 10ft XH Shimano Aerocasts just sitting there. Must be fate I concluded and got one.
So there I have my new spinning rig for the new year. Looking forward to donning the wetsuit and heading back to Struisbaai shortly!
BluFlu
Here she is - don't be fooled - the spool capacity is equal to an 8000 Shimano!
Ben REINERS
That is one art piece !! Explain more about the reel , how new old etc. Seems as if it might have a history behind the bailless reel ?!
BluFlu
Nope they are very much current and in production. The claim to fame is that the entire reel is sealed and filled with grease and oil with a sealed drag system. Makes it 100% waterproof and apparently very hardy. They are the choice of the surf (read wading) fisherman in the states. Typically come out in left had winds (ala yanks) so this was a pleasant find.
The bailess construction is really just an alternative to the bail. Effectively you just unclip the line and when you wind in after a cast bring the line down to the spool and it is picked up again. Again pretty much the standard with Van Staals although you a couple of years back they started making bailed versions.
So simple and so light it really is a pretty piece of bling!
foot soldier
hardcore reel,,alot of the guys in america who have a vanstaal put on a 7mm wetsuit and swim upto 300 meters off shore and float around out the back of the surfzone casting lures at mammoth bass,mainly at night,,its called skishing coz they get towed around by the fish,,those reels are designed to be used underwater,and the reason for bail less is because the get such a pounding(when climbing onto offshore reefs with waves dumping on your head your guna knock the reel on rocks now n then) its just 1 less thing to break on the reel,,,,those reels are sealed and oil filled,,sit it somewhere for a while and see if it leaks,if so then youl need new gaskets,,they recomend a service once every 12 months,but if your handy with a screwdriver then check out you tube'servicing a vanstaal' the only downfall to these reels are lack of casting distance due to the hourglass like line lay system,make sure you dont overfill the spool or it will be windknot city,,but you can make up for that by swimming out as far as you want with the thing and then cast it,,,alternatives to this reel are zeebas,and the new penn torque which isnt a 'swimming reel' but is made to be dunked
BluFlu
Shot for the heads up. No 7mm wetsuit and bobbing around the backline for me with the toothy critters that swim around here.
Zebco has just serviced the reel and filled it with grease. Bit stiff so an oil change is called for but I will leave that to Warwick my very own reel wizard.
BTW love Zeebass as well - unfortunately they are only available in left hand (what they call right hand ?) and my left hand is maar lekker dom!
foot soldier
id imagine it would be very stiff to wind,oil fill it,the thinner the oil the smoother to wind,,but too thin it will leak so you gota find the right weight oil,,use a thick car engine or gearbox oil btw
Fanie
Ek is nie 'n koffie grinder fan nie maar ek moet se dit lyk na 'n goeie katrol. Sit my maar op jou erf lysie.
BluFlu
My erf lysie ... :) LOL
So tydtjie terug het ek vir my vrou verduidlik wie van my vriende kry wat. Maar nou is sy onder streng instruksies om alles te verkoop (nie teen de prys wat ek gese hulle kos natuurlik:)) en die kinder deur skool te sit!
janna
hello blu flu
  waar is die Zebco ouens waarvan jy praat?
ek het so 'n maand terug 3 zebco ''toebek'' katrolletjies vanaf US gekry--nogal duurderig ook--so ongeveer 500 - 600 rand elk.
  ek het nie geweet hulle is hier beskikbaar nie?
