Howzit oes.
Ive started taking estuary fishing more seriously after catching a nice size cape stump in the river a while back, so i decided it was time to move away from the passion stick and get a proper ultra light setup.
The setup i chose consists of a 2.75m Elbe slip stream fly rod (5wt) paired with a 4" K.P and topped of with a couple hundred meters of 4.2kg suffix high abrasion. all i can say is WOW.
This thing is beast. Even the tiny little stumpy in the pic below was a descent rev on this setup
the rod has more backbone than you would imagine and would be great for light tackle gully fishing too. the little K.P is also perfect for casting 1/2oz sinkers and a small bait a descent distance.
If your interested in a good little setup for scratching for shad or bream or estuary fishing, this is as good as it gets. it all comes at a reasonable price to, just R550 for everything mentioned above.
you will however have to grind away at the K.P to make it fit in the reel seat (shave down the metal that fits into the reel seat) but its a quick job.
. the rod has more backbone than you would imagine and would be great for light tackle gully fishing too. the little K.P is also perfect for casting 1/2oz sinkers and a small bait a descent distance.
