OK, so I got my very first muliplier reel yesterday - a very basic botom of the range reel, to first see if I can manage or like them and will try it out over the weekend.
But I need some advise as to how the thing works - I have the basic idea as they operate on the same principal as my bass baitcasters - just need to verify somethings - so your help will be appreciated.
OK here is my take - please add or correct me if you can :
The button on the left, that switches the reel to a ratchet sound - it that just so that you can hear an audible noise when the fish start to run - or any other function ?
On the right ( working from outside inwards ) you have the :
Crank handle - no explanation necesarry ....
Drag lever - to adjust drag to required level - got that covered
Casting brake adjuster - adjust required level of brake resistance- dependant on lure weight - to minimise overwind
Then the lever that says on - off - ( brake lever ) this I suppose it is your lever to release the spool for casting ....any other function ?
The basics of casting is pretty much the same than baitcasters - thumb control etc etc, I imagine.
