my complaint about the shimano trinidad and torium
sakkie7116
Shimaiwa wrote:
Without the cover
I think your spring is a bit to big in diameter. Try a thinner one.
Mussle Cracker...Mine is in for quite some time now and is still sitting perfectly in place. I think that when you do this is to get the right size spring.
Stander
Where is the best place for me to take my TN30 for a service. Doesnt make the clicking sound and drag is not 100%.
did you take the handle off ..cause that little thing that makes the click sound shoots out when you take off the handle...if you dont come rite..my office is in wynberg ..just pm me when you in the area and i will service it ..it takes about 30mins to do...
deenamoodley
hi guys
where can i get a spring in durban?
are the spings made from stainless as there is the issue of rust and corrosion
your help will be appreciated
Mangi
Went to four hardware stores yesterday looking for small springs and all of them looked at me as if I was crazy!!
Where can you find these springs?
Put my star clicker spring in there for now, but would like to have a few back-ups.
Joker
Hey mangi. Try goodwood sports. They sell the drag clicker springs at r10 a piece bought some there already. The small little pin is r35 so dont loose that hey.
FLUKE
I must admit that I was sceptical at first when I read this post. I felt that if the ears on the pawl were tight and it was oiled and not greased then there should be no problem with the pawl engaging. Then I crossed over to the dark side of Shimano and got myself a Torium 30. I did the other upgrades and was convinced that with regular maintenance this mod would not be necessary.
I was wrong, within a few hard pulls the antireverse pawl was looking very 2nd hand. So I had a close look at how this all works. If the pawl is half way between the teeth then it does not have enough time to engage 100
% and you have maybe 50% contact area between the pawl and dog gear. This is aggrevated by the fact that the Shimano anti-reverse bearing & the sideplate? seem to have a lot of flex. So even though the bearing doesn't slip the flex in the anti-reverse assembly allows the hanldle shaft to reverse a little and engage the anti reverse pawl. This will only happen when the pawl is halfway of less between the teeth. This mean that the flex allows the pawl to engage but with only a 50% or less contact area. If the pawl is further away you won't have the problem as if the pawl does reach it will be 100% engaged.
So if you have the spring the pawl is always 100% engaged!!!! as it doesn't rely on turning backwards to engage. If your a sceptic have a look at most damaged pawls and you'll notice that at first the damage is generally less than half the height of the tooth on the dog gear.
The irritating drag clicker spring is inded the perfect size and is put to much better use making your Torium click rather than shooting that little pin across the room everytime you remove the star drag.
So if you're a sceptic like me and you think your Torium or Trinidad?? doesn't need this mod then you're wrong. It probably isn't necessary for edibles with .45 line BUT rather safe than sorry.
