My air canon. Made from pvc pipe. All pipe and ben
Jim Cooper
I've been following this thread with great interest and also intend building my own BomKannon.
On watching a number of posts on you tube, I see that they all use PVC Primer before they apply the PVC Weld, and then apply the PVC Weld liberally to both surfaces before joining them, this could probably solve any leak problems you may have in the pvc joins.
With regards to modifying the Sprinkler valve here is a page that shows how, the valve might not be exactly the same but the principle is, also note the safety feature :http://www.thehalls-in-bfe.com/GGDT/library/valve_orbit1_mod.html
connas
gebruik net n kleiner pvc pype die groote wat golf balle kan skiet , hier koop jy n golfbal by n caddy vir r2 aan en hulle het gewoonlik n redelike klomp
al wat ek sal se is manne moenie julle staal dakkies bydie huis vergeet nie julle sal spuit wees as julle dit doen hahahaha
Naruto
Have used my cannon last week at Bronkies. Only caught fish after feeding. Can surely recommend using some form of feeding at Bronkies.
connas
middag mede hengeaars
hoe lank kan die gun sy lig in hou en hoeveel bar is dit omtrent maar die mees belangrikste vraag , hoeveel skote kan jy daarmee skiet voor jy weer moet air insit ?
FRothmann
All fun and games until you over compress your chamber because you want that extra bit of distance then......BOOM!
AYOBA!
Naruto, is it possible to use the canon to shoot a big treble with a thin strong cable ? If it is then it would be nice to use this with a winch to remove some of the snagged lines in the swim?
Naruto
I know some guys use it to shoot hooks over walls to scale them. It would be very possible I think.
WilMaarVisVang
Geagte Boeties,
8 years ago I was tending my sick dad in Jeffries Baai. During an evening stroll on the beach all walkers were shocked to hear a 35mm cannon go off!! All us ex kaki guys dropped down to our knees, then slowing peered over the dunes edge. A skelm of a teenager had a whopping great what ever it was. Three of us runover to investigate. Us fellas light on the head hair were told the latest craze was patato and pumpkin guns? Later back in Auss. I looked into the systems and liked the golfball system as an intrudrer defence gadgit.
Seeing the serious long distance surf casting was becoming an issue I planned to upgrade the potato gun. I had the idea off frozen bait shells to patent stage on paper, then family issues shelved the idea. Now products are on the market! Like Yankie BUF.
Procrastination got the better of me. I salute you go getters! Doers.
Bait balls for carp in Europe are netted in PVC systems by Korda.
http://www.korda.co.uk/fishingtackle/pva-systems/
Surely these frozen as shells shoot further.....
I will let you know how my system works on the Aussie coast.
:walk
