My Abu is saved
Hooked
Just want to say a great big thanx to [color=#006600]Van The Fisher Man[/color].
He undertook to repair my Abu Garcia CT C3 Mag Elite.In spite of the parts being discontinued he made a plan and the reel is on its way back down to me on Monday.
The total bill was R0,00 which was an even bigger suprise.
I am really happy to get this reel back , its been out of action for a while before I sent it up to Van the Fisherman and I have been missing it quite a bit.
Great stuff , and big up's :first
Hooked
@Van
I noticed you replaced my cast control bush's that I had lost.Thanx , the damm things keep dropping through my big fingers when I service the reel.
One thing I noticed is the new one's appear to be oiled , If they are what oil are you using.
Thanx
Hi Hooked,
The cast bush on your reel should have always been oiled, the oil that I used was of my own secret stuff, but the right oil to use is one of the following Abu Garcia Rocket oil, which even I battle to get hold of, the next best is Rocket Fuel. I'm not sure who does the stuff, but it is out there. Another one to try is Quantum Hot Sauce, but it's a little to thick for my liking, the thing to use is a silicone PTFE with the thinnest viscosity that you can find and put two drops on the bush after every trip to the beach, this is nessecary as the oil is so thin and getts used up by the reel vary quickly.
::jdfis
Hooked
Thanx for the info Van
Can u tell me why the oil is used?Is it to make the bush slip more or to add weight to the bush or something else.It just strikes me as odd to oil something that needs to grip (I think )
Thanx
Hi Hooked,
If you can remember the old bush that was in your reel, you will recall that it had no hole in it for the oil, in the older models the whole reel needed to be stripped for the oil to be applied, with the new ones it is possible to just remove the cap and put the oil in through the bush.
The oil that is needed, goes in where the shaft is going to sit in the bush, the bush it self is free floating and doesn't grip to anything. This is done so that the spool shaft gets less friction than what it would if it was directly connected to the side plate.
And in conclusion, It is this design that allows you to cast this little reel in excess of 250 meters, it is also the preferred reel for distance casters the world over.
:wfish
Hooked
[color=#006600]Van The Fisher Man[/color] wrote:
Hi Hooked,
:wfish
Thanx for the reply , sorry if I sound like a twit when asking these questions but one thing I learnt early on is that here in SA we totally under estimate these reels and the advice you get from the local chop shops is bollocks.I have been advised to take out the brake blocks , take out the mag's , oil this part , dont oil that etc etc etc which totally kills the purpose of this great reel
Would it be alright if I gave you a call next week to get some more info?
