More on the Pulley Rig ...
BigBass
Just noticed a post on the site somewhere about someone using the Pulley Rig and losing a good fish ...
Remember, you must use line of at least 0.80mm diameter up to 1.0mm diameter for the line on the "pulley portion" of the rig which runs freely through the swivel eye.
As an alternative to this swivel, use a No. 5 Owner Solid Stainless Steel Ring (rated at 150lb test). This ring has a larger diameter wire than swivel ring wire and is easier on the line too ...
BigBass
You could also try the Fox Pulley Rig Bead Swivel, but these are very expensive and hard to get in SA - I am also not sure at what lb test they are rated.
