Why Sprite? Do you use Sprite when you at the dam?
Just use normal tap water at home. Is use tap water always, even of I am at the dam, dont want al that green or muddy water n my mieliebom. Will only use dam water if its very clean.
So yes just use tap water at home before you go, but dont do it the night before, you still want fresh feed.
Nothing wrong with sprite to make your bom with if time is a problem and you don't have dam water.
Jean Claude I disagree I can most of the time smell strong chlorine in my normal tap water plus I have a fish tank and if I replace my water without treating it my fish die within a hour or 2. That will chase the fish away.
Jean Claude is more correct here...... I watched an angler boil water to get rid of Chlorine only to add a cap of almond essence to 10ml of water to make an almond dough.
Tap water won't kill any aquarium fish...... change in temp from old water to the tap water temp will however kill them.
The 500ml of tap water in 1kg of feed into 500'000'000 liters of dam water won't have any effect on any fish.
We have medalled in every one of the past 10 Junior SA's and had 4 Individual champions and we make the whole teams fee at the camp with tap water before we go to the dam (that should be proof enough that tap water has ZERO effect on the fish.)
