Aaaaahhh...gooing spoon for kobbies amongst the bricks...NOW...very few get it right...very few have the heart or stomach for it ...BUT...once youve worked your spots out AND here you do not want more than say 3 or 4 and you HAVE TO REALLY work them...
There are many things to consider ....and there is NO short cut...like weedless lures...fancy braid ...this rubber that plastics ...V shaped spoons etc etc...
First things first you will need to look at what rod you will want and herein lays a dilemma ..coz you need a tip that is pretty sensitive but not soft and you will need a rod that has enough back bone to muscle that kobbie in and around the bricks....
Here to you can just go moer n soek and maybe get lucky...
The real secret is find those bricky areas that you would not even THINK about throwing a bait in , let alone a lure...look for the water movement as it rolls in and watch for lulls and eb n flows...
Then ..on a spring low tide go look at it and make metal maps...then go look on a spring high and on neap tides as well...
What you want to do on a nice clean warm day go and swim it with a pair of goggles and then go draw a map..
You want to throw S shaped spoons that push water and are between half 0z and max 2oz...
You want a rod up hold and a medium retrieve with a reel ratio of at least 6:1...
The reel should be a multiplier and not a coffee grinder ..
Rod size should be between 10 to max 11,5f and reels to look at would be Daiwa SL 30/20...Abu C level wind series...and even the slow Shimano TRG can do the job...
good quality line with at least a breaking point of 12kg ..no swivels ...bimini twist attached to a 60lb clear trace of 1 meter onto a Swannel kwik clip...
THEN..its time to go gooi and test your spot out...
Watch EVERYTHING..and make notes on conditions catch or no catch...
Some pointers for you//
Kob like a rising barometer
Water temp between 17/20
Clean water with nice even working white water
NO SURGING
AND a sure sign they around IF you see lotsa bait fish in the shallows...
TIGHT LINES!!!
