fishersteve1972 wrote:
Bennie is it a mission to attach the front dropper part through wire style
Hi,
I normally cast these with the wires in place.. But with wood poppers, The hole in the belly section meets up with a hole drilled right through the lure. So all you do is take a piece of wire, make a loop on one end and pass it through to the back with the belly swivel in place. Then you fit a small washer, make a loop and wrap it back on it's self towards the lure.
I hope that make sense.
B
