surfboy wrote:
Hi Cuban, you know that I am one of the guys who think the Trini and Torium 14's are easy to cast and control........I am going to be waiting for your casting results in anticipation.....the brake blocks work.....but interested to see whether Mag-it versus blocks gets more distance? Now that we are looking at the 14's....What are your feeling about Mag-it on the SL20?......seeing that you love your SL20..........
Cuban Cigar wrote:
Will be casting from 2.5oz all the way to 5oz for the different applications !
Will let you know when final setup is determined !
Hi Surfboy !
Your timing could barely have been better, to ask the question about the sl20/30sh !
I'm expecting the magnetic stainless magplates and the aluminium conductive spool discs for these two reels, to arrive here today, via courier, from the engineering shop that does all my cnc laser cutting !
I will then probably take the pics tonight and post on the topic.
My prototype performed really well on both models and have the added advantage of full adjustibility, when compared with the break block options - it is also dead quiet, with none of the high rpm "rubbing" of the blocks inside the centrifugal ring.
Watch this space after my test casting with 2-5 oz on these lovely little reels with their light weigh synthetic spools !
Cheers !
