Lures for Garrick
ShaunW
Hi Guys, I have been fishing Swartkops for a while now and I have only been catching undersized Spotted Grunters and Steenbras. I really want to catch a Garrick as I hear they give a hell of a fight.
Please can someone let me know what lure can I use. I have a Daiwa Megaforce 7ft Rod with a Daiwa Crossfire 2000 FD and 10lb Braid. What will best for with this setup?
And what spots at Swartkops should I try to target these fish?
Jakes101
Hi ShaunW.
You'll need a variety of lures and quite a bit of time to target these fine specimen as they can be very illusive and quite fussy at times. But boy do they give you a good pull if you manage to hook one!!!
Ideally you'll need some spoons, surface lures (Strike Pro's, Predator plugs, Surface poppers, etc.), some plastics and leadheads.... to name but a few! ::S
Depending on budget, start off by getting at least 1 spoon, 1 Strike Pro, 1 Surface Plug (Predator 1/2 oz should do) and one or two leadheads. Maybe also some McCarthy plastics and 1 or 2 jig heads as well.
Go have a chat to the guys at Alcocks, they are very helpful and will point you in the right direction.
Also search "Spinning Swartkops" and you'll find a lot of useful info on this site.
Also see:
http://www.sealine.co.za/view_topic.php?id=47169&forum_id=25&highlight=spinning+swartkops
Then spend as much time as you can at the river and soon it will be tight lines!!
:fishn
ShaunW
Thanks for the feedback, will head off there today and will be at Swartkops early Saturday to try it out!!
PatrickC
Strike pro poppers are the way to go, especially the ones with rattles or the bubbler type with slits where the gills would be. I've always had success with silver, pearl white and white and yellow coloured lures
basstacle4see
If there is one lure I believe in, it is a Storm Thunderstick Jerkbait in olive colour (not sure what colour code is) I have caught leerie with it when there is no chase on surface lures. Also worked well on Kosi lakes on GT, Big eye king, pick handles, Rock Salmon and even caught a huge Natal stumpnose on one. In the Sedgefiedl/Swartvlei lake I caught leerie, Shad and even a Grunter on this lure. Only drawback is the lure is not very heavy, so casting distance is not so far. Fishing from a boat this does not bother to much though
