Luminus paint for rods
Romelwa
Hey Guys.
Does any one know of a paint or sticker I can use on a rod tip for night fishing.
Must be similar to those yellow reflective caution tapes ( can be seen from miles away) used on trucks.
Tried the reflective tape, but its too stiff, can't wrap around the tip.
Hey buddy..there is different types off reflective tape that u can get..the 3M products have a steel mesh built into it in a diamond shape to give rigidity to the tape..the reflexlite products are more similar to normal tape and can flex around a thin rod very easily...this tape can be differentiated by the name embossed into the reflection material...i hope this helps...
buckled
why do you want reflective tape. If you hold your rod you will feel the bite or if you have your rachet on you will hear it.
Mel G
Hey Romelwa, i use the glow sticks that are available at the tackle stores (they approx 3cm long)and some are visible/glow for up to 75m away, i just carry some masking tape in my bag, and then stick the glow-stick to the tip of the rod...when i'm done fishing for the night, i just remove it, and its done, rod looking back to normal... its definitely better than reflective tape, cos it does not affect the flex of the tip of the rod... Hope it helps, and i promise its worth a try, and they are really cheap, and store well...
Mel G
zzzz
I agree 100% with Buckled, but if you don't like his idea then go with Mel G's its also an excellent way of keeping your rod looking normal in the daytime!!!
ICTHYES
Romelwa
hey guy .
sometimes when bites are slow, I place the rod in a stand and walk 50m to the next buddy.  With the reflective tape I'll know what's happening when I cannot hear the rachet.:dunno1
