Lost info re wind-on leader
Cobus Blouberg
I am struggling to find info on the basics of the wind-on leader practice in our conditions, and searches here render 'error' messages in some instances, for obvious reasons.
Does anyone know of a thread that deals with the basics and is still around, please?
I want to start using it as I often chuck a sinker or the whole shebang, even with .45 to .55 mm line, six ouncers typically and going for edibles with a Waverunner or Purglas 350/3. If it does not break off, it goes a good distance but I need something to break the shock.
I always just used 'from spool to swivel', time to grow up now 8)
What I got so far was 2 m leader line from the tip, eight loops around the spool and ten pounds line strength per ounce of lead - so 60 lb leader for a six ouncer.
And what is the popular opinion, with the sort of set-up that I have described - influence on casting distance, other risks, etc?
Any comments and pointers will be highly appreciated! I almost feel guilty clicking on 'Post a New Topic', but here goes!
sakkie7116
http://www.sealine.co.za/view_topic.php?id=30670&forum_id=57
http://www.sealine.co.za/view_forum.php?id=57
There you go Kobus.
Trophy
Hiys Cobus Blouberg,
I'm not sure what you are after? Are you looking for info on how to make a wind-on leader?
If you are after that then you can follow my tutorial in the knot section.
http://www.sealine.co.za/view_topic.php?id=44644&forum_id=44
Regarding when to use a wind-on leader...well that depends on your rod and more important the size guides you have on the rod.
I would not use a wind-on for anything under 0.90mm leaders. Most standard rod straight of the shelf will have guides fitted as STD to coupe with knot sizes of this diameter.
You can knot and cast 1mm leaders, but I like to use wind-on leaders from this diameter upwards. Any knots in mono from 1mm upwards start making a horrid clunk through any size guides. They will go through, but you will snag a knot and get a over-wind and sooner than later you will clip a ring or damage a guide.
