Looks what these clowns have done to this Land Cru
kraken
PEETO wrote:
It is a fact that you get better mileage out of a Toyota then what you would get out of any other vehicle in the same class. My KZ-TE has 400 000 km on the clock and still going strong, with the regular changing of oil, diesel, and air filter every 10 000 km.
Ah! A wise man indeed! I also own a KZ-TE although with not even half the klicks yours has.
My feeling exactly with regard to meticulous attention to servicing.
As for the landcruiser at the start of this thread, I'm speechless......
I've seen quite a number of similar sorts of abortions on our local roads where some clown with zero taste has turned a perfectly good bakkie into something which should be destroyed in a low level airstrike, but THAT! No man........
PEETO
True, i bet you nobody in their right mind is going to pinch this ugly duckling. He does not even require a tracker
