I'm a bit pissed that I broke the CDI charging coil wire as its gonna be a PITA to rewind as the wire is 0.20mm thick so will take 100's of meters to get the desired resistance.
The charging coils are piss as there are only 136 turns of 0.8mm wire
The firing pickup was carefully removed from the housings and is still 100% in spec.
I also left some of the original yellow wires on as to get it all wired up correctly
The stator windings will be varnished when done, the new ones dont have the Epoxy coating so I really dont think this will be an issue.
Total cost to rewind will be under R700.
of course I could send it in and pay a little bit more but where is the fun in that.
