Loading Boat with Winch
WILD
Gentleman,There are a few theories on how to use the winch.
Some say the winch cable should not go over the rollers/guides at the front of the trailer and you should pull the boat straight from the winch. Any comments
FRITZABU
We always used the roller, on the trailer and run the cable over it. You only need to be sure, the tow hitch is in the centre, under the winch and not to the side.
We once used a vehicle with a off centre tow hitch and it caused damaged to the trailer.
 ((goodp_Spot on. Same here.
Another thing you can do is to put a chain on the front to limit the break neck to it doesn't dig into the sand. Then you winch and push the trailer in under the boat instead of dragging the boat on the sand.
dugongboy
I winch straight from the winch (no roller) but as Bennie said I have chains and the trailer gets pushed in 2/3 of the way - very simple!
