Little pocket rocket
KarpKing
Hi guys was on the vaal this weekend in the storms wind and rain caught this super yellow yellow fish on a red hotspot. one wicked question I had one on in ankle deep water and it went to go in to the main chanell but to get there there is a Sh@t load of grass patches and well it broke of how the hell do you catch that yellow there because that thing was as long as my arm and there is no stopping like we say in afrikaans (dis 'n tryn)
KarpKing
ja op 'n rooi caddis, mar het die selfde dag 2 groot geelvisse verloor en ek weti hoe om hulle daar te vang nie, het enige iemand dalk vir my 'n plan behalwe 'n gooi net haha
Unlimited
n man my die naweek gese jyt regtig nie nodig om n tippit aan te sit nie... kan gewone 4kg of 5kg lyn ook gebruik... ekt n dvd waar hennie papenphus dit ook gedoen het en nogsteeds n klomp gevang het
Yellow Monster
Yip, you right. No need for tipped but a good thing to have is a good 4kg fluorocarbon line. Why, because the yellows don’t see it as the line becomes invisible in the water. It’s around R70 for 30 meters but it really is well worth it.
I caught this small mouth 3.8kg on a hot spot with the above line.
Giving away all my secrets……!
Williaby
I would strongly recommend that you don't use fluorocarbon for Yellows.
Although it is virtually invisible when in the water and sinks well due to its lower density it has virtually no stretch and you will lose way more fish due to this. And with the way a Yellow takes, particularly in the faster sections, you are much more likely to get snapped off when a big one takes off with your fly.
Besides, even in the clearer lower reaches, the visibility on the Vaal is never really that great so there really is no need for fluorocarbon.
Just use plain 1x - 4x monofilament and this will do you fine. It has loads more stretch. Some of the best Vaal fishermen I know fish with plain old Maxima Ultragreen and they fish most people off the water.
Just my R 0.02
Yellow Monster
Just my R 0.02
That’s great information bud, I have lost a few that have hit the fly hard but always put it down to the breaking strength of the line. (or my crappy knots – haha)
Will change over and see if there is a difference
Williaby
No worries, man. The last thing you want is to lose the big ones.
Although I know guys who catch well on Maxima, I personally prefer normal mono tippet material as it has lower diameter and therefore sinks quicker getting your flies down to the feeding zone faster.
I usually use 1x when the visibility is bad and if it is good I will scale down to 3x but it will be a while before the Vaal clears up enough to make that necessary.
Stronger tippet also has the advantage of enabling you to land the fish quicker and therefore not tiring them out as much making for a healthy release and you can also apply a bit more pressure on the bigger ones to keep them away from cover.
Yellow Monster
I caught a 3.8kg on Fluorocarbon – (see avatar) and would have been worried about a 1 x tipped. I was fighting a stretch of rapids and she was so feisty that it took me a long time to land her but eventually netted and got her back safely.
I use some really great looking tungsten weighted circle hook flies (dropper),  that really helps getting them to the bottom quickly and the circle hooks have helped with less hook up’s. ( I think it has)
Will definitely switch to normal line though as you make sense.  I have experienced lost fish because of this, almost sure of it.
