Line twisting on its self.
Jake the Snake
Hi Guys
I Have recently respooled my line with the new double x black and it seems that only with this line that my line is twisting back ont its self if its not on the spool.
HOw do you get rid of this or avoid this from happaning, as i have trired all of the "old boere raad" to get this out but seem to still have it on some spools.
TotalNoob
Seems when you spooled it, you had the spool facing the wrong direction and as a result the line is twisted both ways causing it to twist onto itself.
Did you use a wet cloth when you spooled?
You need to have someone walk out your line and then respool it with a wet cloth against the line.
Jake the Snake
Sh*t bud to walk out 250m of line is gonna be a stuff up.
What i have done is to put the line i a bucket of Water so that if it wants to twist it self loose it can. But this seems to make it even worse. But for some reason its just with the new Doulbe x lines the black and the orange.....And these line are so nice to fish with other wise.
How do you get this out of the line with out re spooling?
Naruto
as ek daai lyn opsit laat staan ek die spoel op sy kant met die gleufie wat die lyn vashou na onder. Dan katrol ek bo-oor die spoel sodat hy nie omval of rondrol nie. Werk al jare vir my. Neem in ag dat ek net 200m op n spoel sit. Die res is backing.
Jake the Snake
Sjoe ek sal dit bietjie probeer. Ek self sit ook net 200 - 250 m op `n spool.
Ek het een van daai lyn winders gekoop by westerns en ek dink dit mag dalk die rede wees hoekom hy so *** (admin JPS) aanjaag.
Sal laat weet as ek nie regkom nie.
