line rating to casting weight equivalent
Pslatarix
hey chaps. just bought a shimano exage ax stc boat rod. it has a line rating of 50lbs but what lure weight could I use on it? don't want to go and put a 200g popper on it and snap it. really nice rod too. thanx guys.
The line rating is based on what the rod can handle in terms of fishing pressure. The rod might be able to handle a 200gr but wouldn't necessarily be able to cast the weight.
If you spool up a reel and then hand the weight off the line that runs through the guides you will feel if the rod can handle it at all or not.
Did a quick google search and there are a hell of a lot of exage ax stc models so one would need more details as some are 30lbs line class but 10-30gr lure
Best advice is to call RapalaVMC and ask them on Tuesday
(0)11 794-6950
Pslatarix
ye did the Google thing myself . I've got 80lb braid on my grinder but again the grinder can't produce 50lbs of drag either. did the door handle test ( tied the line to door handle, lock drag, walk backwards holding the rod 90° as long as you feel comfortable or until the reel starts releasing line) and no dramas. also tied a 150g popper on to it and the rod when held horizontally had only a slight bend in the tip. the rod isn't available in rsa to my knowledge Craig. I got it here in the uae. it was designed as a traveling rod for the European market. one of the reviews I read said they had used it on congers tuna and coalfish as well as sailfish . if it can pull a conger Im sure ill be able to pull a med geet or aj off a reef . ................... I hope...............
The range includes light telescopic rods, tuna standup rigs etc, etc seems the whole range is dedicated to traveling
Would seem you have one of the Beefier versions, any other codes on the rod
for Example TEXAXBT3050
Pslatarix
tested the rod yesterday and it handles a 200g popper like a dream . its a shorter rod so Im only getting around 60m but that will do. going to miss my racepoint and carpenter on this trip.
