Line for reel
kp11
Ihave just purchased a assasin beachmaster rod with a daiwa saltist 50 reel i am just starting out at this type of fishing and would like any advice on what line or braid I should use. thanks in advance
What do you want to target, KP?
Edibles... go with 600m of 50lb Braid (Whiplash, Tuffline XP or Sufix) and then 0.40mm -  0.45mm topshot, (Giant abrasion, Double X or Daiwa Tourament).
Inedibles... 600m of 50lb braid with 0.50-0.55mm topshot.
kp11
When you talk about topshot I take it this is the line that goes on top of the braid. How much is required.
Kumz
My personal choice wud be ...45lb braid & 0.5mm line .
but for a novice , i wud say , load 600 m 045. start fihing 1st , as & when u r ready load braid etc ...
My 2c's
NetSoGroot
My 2c's
Beware of braid being a novice. It will cut very deep if you make a mistake. Bly by "mono" tot jy weet wat klap.
My opinion on this... a beginner learning how to cast with a multiplier and all that... would be much better off with using Braid underneath topshot nylon. The reason being that there are going to be many overwinds and line getting damaged... so you only need to replace the 150m +/- of damaged topshot... It will be very rare that the overwind extends all the way into the braid... Using nylon only... that overwind is going to extend a lot further than 150m....??:dunno1
Pylstert
If you are using 0.45mm you can always fill with 400m or so nylon and then fill up with about 150-200m nylon. You will seldomly cast to the knot when your a novice.
I used to fish with 400m nylon before braid and just replaced the top nylon and never recall getting an overwind into the last 400m of the nylon. Reefer, what would prevent the braid from making an overwind compared to having nylon underneath?
