Howzit...
Every once in a while i like to check on condition of my reels, doing mainly salt water fishing the abuse a reel can receive from this form of fishing can prove costly and unnecessary.
General idea would be to check bearing's and screw's. So out with the old tackle/tool box to lube bearing's and grease screw's, with the price of modern reels the last thing you want is screw's rusted up and stuck in thread and damage it can cause if stuck and trying to loosen it.
- Toothbrush. Used to clean reel of sand and other dirt.[/*]
- Screwdriver to loosen screw's.[/*]
- Oil. Whichever you prefer.[/*]
- Plastic tub. Used to bathe bearing in by simply placing bearing in and covering it up with lighter fluid(personal preference) for about a minute and removing bearing and placing on a kitchen towel for a few seconds and adding oil.[/*]
- Grease. I use the Penn grease for applying to screw's etc.
