What are your thoughts,
I will be using this for Targeting Leery, Skipjack and Kob in Rivers.
The reel is a choice between the Sahara and Sedona, the Sedona is about R450 +-R100 cheaper than the Sahara and has one more bearing but has a graphite frame instead of Sahara's Aluminium frame. On such a light outfit I doubt I need a Aluminium frame that will just corrode.
The 6'6" medium light Passion Stik is probably the best value for money and is highly rated by the Alcocks (before they started promoting sponsors products) and at only R320 my minds pretty much made up here.
The Triple Fish Gator Braid is very thin 0,08mm for 15lb, I actually wanted 10lb but I didn't want to go thinner than 0,10mm. The alternative is the Suffix Fuse 0,12mm which is 10lb I think. Gator Braid is about R250 for 300mtr & Suffix Fuse is a few Rand more for only 250mtr.
I have mentioned prices because this is the budget I want to stick to.
I know Fireline is good but it's pricy and then you have a weak point where the Fireline and backing are joined so I'll rather go with one line
