life span of braid.
skrops
Okay so now I have braid as backing on my reel I have fished with it, and the line has gone in the sea a couple of times.
how will I know when my braid needs to be replaced?
Kumz
I wud agree with Both replies so far but as Reefman said you must Check the braid ..
After each trip to the coast you must clean reel up well .
I personally wash spool in luke warm water to get rid of Salt Residual & dry out well ....
Sage
But one of my friends said you gotta get it done at a tackle shop,because you cannot get it tite enough by yourself????
It's easier if you get them to do it, but it's quite possible to do it yourself with someone else putting some tension on the Braid spool...
Nepptune
I am still fishing the same Power Pro 30lb on my Calcutta that I spooled up with nearly 6 years ago!!!
But what I have done, on both the calcutta and Fin Nor spinner, is cut off the first 50 metres of so, then remove all the braid, then respool it backwards onto the spool... this basically gives you a whole new section of "working" line...
Sage - Mate braid needs to be spooled as tightly onto your spool as you can get it.... what you can do is get someone to help you and get them to "brake" the spool with rubber or cloth while you wind on, or even better is to wind the braid onto another reel, preferably a large one. then up the drag to a point where you have sufficient tension on it and spool it onto your reel you want the braid on....
Kumz
Some tackle shops can do it fast but it will be un-even after a few trips -Kathie had a problem with a repuatbel tackle shop ...once they did his ...
You can get someone to help you ..Get a bucket of water & use a glove & wind it on tight  & evenly ..
Kathie & i did mine .. still good as the day we put it on ..
Will take sometime & u will feel the Deep burn ....
Good luck .... ;)
For it's price.... ? hmmm
  1. TUFFLINE XP [/*]
  2. Sufix performance[/*]
Tuffline is very reasonably priced and rated VERY highly by most overseas anglers. But many guys reckon Berkley Whiplash is worth the extra expense....
